- Location
- United States
$15k
late model tacoma 4door trades welcomed.
Truck is now located in Aurora, CO.
Here are some pics (currently has 37" trxus M/T on it...>95% tread, extra grooves and sipes added.
http://kumar.cruizer.net/Krawler_Build_Up/
other pics @
kumar.cruizer.net
There's a lot to mention about this truck...please email if seriously interested. kumar @ cruizer . net
of course, it has lockers
with modified hazard light used as CDL.
Welded castor correction (tie rod hits the front control arms on occassion, no biggy, just a "clang")
wet okole seat covers (two toned)
It has manual hub conversion (aisan parts)
the storage box is made of hardwood plywood and stained/carpeted.
has adjustable panhard rods front/rear
had beefed up drag link and tie rod
new rod ends this last summer
j springs
mr gasket spacers and OME spacers used.
CV front driveshaft
AutoRX cleaning on engine (just finished it), perfect compression...need to get the AFTER results...but BEFORE was very good compressions as well
Snorkel
Centramatics Wheel balancers
arb winch bar (taking winch OUT..not included in sale)
Hella driving lights
Gearing is all fairly new (under 10k miles probably)...full rebuild with new parts by professional...4.88 gears
ram mount swivel cup holders (expensive, but your drink never tips over)
eclipse speakers all around
mini 12 volt distribution in center console (gutted old lexus sub out)
17" tundra rims
37" trxus tires
NO SPARE (never needed on anyways...but storage solution WILL accommodate a full size spare.
K&N filter (rarely gets dirty since I have snorkel)
C02 tank not included...but there is a perfect spot to mount it.
Husky liner floor mats (the dish pan style, hold all the crap in)
cd changer (stock lexus)
Gibson Stainless muffler ( I need to clean up the routing though)
Sliders (can be bolted off with ubolts...used George S's design)
PTT replaced
RED antifreeze flush (cooling system is in AWESOME shape)
new belts (PM nothing broke)
new starter contacts and plunger.
new alt brushes
new battery (yellow from walmart)
remote start (need to hook up the tach wire still, but starts within 2-3 cranks)
only ever used shaeffers and/or amsoil oil and filters (all very good stuff)
high flow cat
new plugs (irridium)
newer spark plug cables
new rotor and cap
weather tech in channel vent shades
front windows re-tinted this summer (old ones purpled out)
Uniden CB in asshtray location
Wilson CB antenna with short stick (not whip)...works awesome
...dude, I'm sure there's some stuff missing, but that's what I can come up with right now without being next to her.
hope that helps!
Kumar
Thanks!
Kumar
other pics @
kumar.cruizer.net
j springs
CV front driveshaft
Snorkel
17" tundra rims
37" trxus tires
PTT replaced
new alt brushes
high flow cat
new rotor and cap
hope that helps!
Kumar
Thanks!
Kumar
