I am base lining a 94' 80 that I bought a couple months back. Both birfs done 12,000 miles ago by Toyota Dealer. Both are functioning well but I wanted to check lube level and made an interesting discovery. Passenger side birf had what appeared to be nice dark grey moly grease but the drivers side had drips at the bottom of the four bolts which looked a lot like red tranny fluid. While researching I read another post where someone had encountered something similar. Aside from the drips at the base of the bolts, the joint is dry and clean with no performance problem.
When testing the lube level on that side it appears that there is very little of the pink mystery lube left in the birf. Should I just fill it 2/3 full with Moly and call it good or should I try and remove all of the pinkish lube before adding moly grease? Is there any way to evacute the lube without tearing birf down? Thanks
