Would these help out with front end flex??
Virginia Beach, VA
Just wondering if these would help or not. My understanding of axle geometry is sub-par, but IIRC, one of the limiting factors in the 80 series front flex is the stiffness of the bushings. These would allow the axle to move quite a bit more......
FWIW, you can have these made for any size for relatively cheap.
edit: they are also greaseable....
They probably would however they will also transmit more road vibes to the chassis than the OEM rubber bushings. If this is not a priority and the flex is it's worth looking in to.
Ditto what Chris asked.
Not to hijack but: Chris your red rig is far from "nearly unmodified"
Google spherical bushing and you should come up with several manufacturers.
They are commonly used for the articlated steering cylinders of heavy equipment or any other cylinder that needs to have a little flexibility....
I think they would "minimally" help...but not much...it's basically the design of the suspension that causes the bind. the axle must twist when flexing, (1 up, 1 down) and those bearings won't solve that. maybe the slightest more movement...maybe not.
The radius arm setup doesn't allow the twist, therefor is binding flex. And when you pull a bolt (hitch-pin) setup, you can see how much more that axle can twist/flex.
:cool:
Who is Chris?
/* big hijack
Who is Chris?
The red one in my sig line is my :princess: 's DD. It came to us stock without roofrack or spoiler or hitch and with a near dead tiny battery and a scratchy FM CD changer. It will never get a roofrack or spoiler. I put on a DrawTite III/IV hitch, replaced the battery with an Optima D31a, changed the PHH, changed the oil & filter, flushed the brown mixed antifreeze out through 9 flushes and filled with 50/50 Toyota red and distilled, changed the thermostat, changed the brake pads at all 4 points, freed up a sticky rear slide bolt, inflated the spare and thats it. The dust caps tell me someone already serviced the axles at some point so I have some wiggle room there.
Everything but the hitch is just maintenance. She's getting a CDL switch next week since she had one in her '92 and it helped her in the snow. (I know... VC in her '96... Its $60 and she wants one.)
Now, the grey one on the other hand... That is my toy. If I ever feel I've got it somewhat done then I'll likely do a ROTW write up on it. I might do one on her red one if there is interest.
*/ hijack off
I hadn't thoght about the impact transmission being softened by the bushings. If someone does do a set of these, maybe running the tires soft would help lessen the blows. I know the bushings are getting tired on my Grey truck. I haven't made any decisions on what I'm going to do about it though. Upgrading the rear control arms at the same time has some appeal.
What we realy need to do is to get an idea of what these would cost and then have someone test them on & off road. I'm a bad candidate because I don't get a lot of opportunity to do either. I am interested in following how this develops out though.
Thanks!
Grench (aka Mark)
Spherical bearings will reduce the flex, flex your truck and study the angles. Due to the 4 bushings on the radius arms and the panhard moving the axle back and forth, the bushings must flex/compress vertically and sideways for the axle to flex. Spherical bearings rotate freely, but have no vertical or sideways movement, so would bind flex, unless your moving away form the radius arms.
Softer bushings, slimmer bushings/holders/arms and/or wider brackets, moving the panhard more level with the ground, all will free up flex. Stiffer bushings, OME/Johnny joints/spherical bearings, fatter arms, angled panhards, all bind, reduce flex.
Look at these pix, the bushing is flexed vertically and sideways with very little rotation. Most of the rotation is on the frame end bushing, but they still need to flex sideways, for a radius arm setup soft bushings are the best compromise.
I see,
Oh well.
Thanks,
Dan
I would think you could use a single heim bushing on the front attaching point, and probably gain some steering accuracy, but that can also be done by just putting on the LTX tires vs just about any other.
I have worked extensively with heim jointed suspensions over the years. Even audi uses rubber booted ones in their quattros (rear camber links '86-98), and they are a regularly replaced item vs a rubber bushing. Unbooted ("bareback") heim joints I install in performance applications, I rarely see more than 2 years out of them on the street, less on the track. They pick up dirt and wear quickly.
I'd think a new set of rubber bushings would be money better spent for the next 200k miles...
ST
