Working on the HG
Minnetonka, MN
In the process of an engine teardown for the HG replacement. I am also going to replace the gaskets in the oil cooler if I can get the header off.
I removed the entire air cleaner assembly so I can get in the engine bay. I am 5'6" so I fit in there pretty well.
Throttle body was pretty dirty. I can't believe the amount of grime in the intake manifold and throttle body. My plugs didn't show any signs of steam cleaning. Plug #1 was pretty wet though.
Looks pretty good so far Schwaz!
You gonna do the oil pump o-ring while you got the big pulley off? It looks like something's been leaking up there. That, and I can't figure any other reason to remove the big pulley if you're only doing a HG. Maybe a front main seal?
Go buy yourself a set of Torx sockets if you don't own some. I think I got mine from Napa or Crapsman. They are essential for removing the studs for your exhaust manifolds. If you remove the studs, you can lift it up and off. Otherwise you have to remove the downpipes as well.
Thanks man. I am doing the front main and the oil pump cover seal as well. Something was leaking big... actually everything is probably leaking. I am going to get some Simple Green and clean up that area before I get to work on it. I have a set of Gearwrench Torx sockets. A couple of the manifold studs striped. I am going to double nut those to back them out.
I also noticed my exhaust manifold was very loose. A few weeks before I started the project I smelled exhaust in the passenger wheel well. Now I know why. It never threw any codes... but there is substantial buildup of carbon and other gunk where it was loose.
I am also going to remove the exhaust headers to rebuild the oil cooler. Might think about throwing on a new exhaust too...
More pics of the breakdown... offending exhaust manifold stud. I can't believe how much crud is in the intake manifold.
The PO had the EGR system overhauled. New VSV for EGR. I will be replacing the vacuum lines and cleaning out the valve itself. Injectors are also labeled and ready to go out for cleaning.
I had to clean up the timing chain cover before attempting to attack the oil pump cover. All the screws came out easily except for 2. I haven't stripped those yet... just giving it a rest for tonight and back at it tomorrow.
I got the valve cover off and the innards looks a little dirty. Oil is gummed up pretty much everywhere. Makes me wonder what the oil pans look like. I also think someone was already inside :censor: There is a mark on the timing chain sprocket and a mark on the timing chain and they don't line up... oh well.
Mine is now back together.
Head is us due to a waterway corroded at the back of the engine no 6 cyl i think then blew under head gasket putting all of the coolant into no 6:bang:. would have been uneconomical to fix.
got another head that was polished and ported .
now lovely with new silicon hoses and belts :)
Schwaz,
You might be able to flex the exh man off with a buddy and motorcycle straps to hold it back while you lift the head off.
DougM
Making progress! The stud extractor worked for removing the stuck exhaust manifold bolt. My new, beast-mode, Kobalt electric impact wrench just blew through the manifold downpipe nuts/studs. Hit them with Kroil too.
Just a preliminary look at the exhaust valves makes me think I have a failure at/around #1. Those valves are clean as compared to the rest. The #1 spark plug was also wet when I removed it.
I cannot remove the water pipe that attaches to the thermostat housing. I am just going to wait until I pull the head so I can get a better hold of it.
