So in the seemingly never ending saga of getting my 40 back on the road, I decided to adjust the valves one more time before I pulled it out of the garage. Well after adjusting them, I started it and got it running, but the rockers got louder and louder (I had already put the valve cover back on). So I shut it down. Did not have time to mess with it at that time and was a little frustrated. So I pulled the cover Saturday and found that I forgot to tighten the nut on the #11 valve (intake). No problem, I adjust it cold and figure I can double check it once I get it warm. Well I turn the key w/ the choke out and a couple of pumps of gas as usual, and get a backfire through the carb. Go back through everything and make sure I did not accidentally knock something loose. See that I did not reattach the PCV valve. Reattach and try to start again. Backfire through the carb. Tried 3 and 4 turns out on the fuel/air screw with no luck. Double check the valve adjustments also no luck. Did I mess something up running it with the valve loose or is there something else???? I diid not touch or adjust anything other than the valves and it was running/start fine until I tried to restart it after tightening the nut on #11. Timing is at 15 deg w/ non-USA dizzy w/ pertonix, carb recently rebuilt, head recently checked out (all was good). I have read through of the "carb backfire" threads and am at a loss sine it ran fine before the loose nut tightening.
-Brian
-Brian
