Truck is a 80 with original engine (rebuilt in 15) and harness. battery has 12V across the terminals. New fusable link from coolerman. When I turn the key forward the fuel pump turns on and the seatbelt warning beeper turn on. When I go to start the starter will click and I loose the fuel pump and the beeping. Took the starter to be tested and autozone said it tested good but the gear didn't turn as fast as expected, so I just got done installing the new duralast starter (retained the original). No change . The new starter has an additional ground wire is this optional? Ground terminal at the battery seems to be little loose but all resistance checks have been 0.3 ohms. About to take the battery for load test. It was installed in 2013.
Any other suggestions?
