Wobled crank pulley
Silicon Valley
My crank pullley wobles a bit, is it as simple as tighten the big nut or should I pull the timing plate and check out balancer and the key, or is something related to this thread:
https://forum.ih8mud.com/showthread.php?t=89505
I spent 9 hours working on the truck yesterday, it's the second time I do major modifcations on the truck. On the 1st round, I fixed one thing after another...On the 2nd pass, I am fixing rotten radiator hoses that I installed 4 years ago (Smartened up and used OEM hoses this time), and while at it I pulling the radiator to fix the wobled crank pulley....It just never ends!
Thanks.
The crank pulley will only wobble if it is loose or damaged....and if it has been run loose for any period of time, it is likely to be damaged....
Remove it, and look at it.
Good luck!
-Steve
To save on down time, round up another balancer pulley, a new front timing seal, timing cover gasket, locktab for the locknut, and a new crank key BEFORE you take the truck apart.
Chances are, if your old balancer is damaged, you will need ALL of these in order to get your rig back on the road
Hth
Mark A.
Gentlements, thanks very much for the info...I did some more reading into archives,TT Tech, 2F manual and realized that I'm pretty much fawked too. The engine was rebuilt by PO and compression is good at around 165 for all cylinders. During lunch I am going to get gasket/seal/locked-washer/crank-key at a local Toy dealer. Will also try to source a good used balancer but fixing the crank damage could be tough...
I keep my fingers crossed, my Rubithon plan might be going down the drain. Will come back will more questions later, thanks in advance!
/td
There was just a thread on this. The guy brazed his and recut the keyway slot.
IIRC it was Chef(Alan Loshbaugh) and he posted some pics. I think he did it in the truck.
GL
Ed
EDIT: Duh, you already saw it.:doh: :doh:
Update!
I removed the big nut and crank pulley and....thanks god there's no damage the crank or pulley, the key still looks like new and sits tight in the groove....the seal looks old and tired so I will replace the seal/gasket/key/lock-washer. I think I caught it in time before any damage occurs, I'm so happy I could pee in my pants :bounce: :bounce: :)
Will use red locktite on the big nut. Let me know if anything else I should do.
Thanks.
Poser said:
Is it bent?
Was the nut loose?
That's a good question, the nut wasn't loose, I removed it using an air impact wrench, I examined the key grooves on the shaft and the inside the pulley and there's no worn, I will snap 2 pics later. I thought about the pulley being bent but I remembered not seeing the wobles before my powersteering conversion, there was no chance the pulley hit a rock because there's radiator shield below the crank pulley, and there's no dent in the shield.
Will find a way to check if it's bent when I get home today.
Thanks.
