Thought that rear gasket poked into the bay; too dark to look now.
Here is everything else I need to do:
- Install hood, rubber, lift supports
- Install bumper and grill
- New Windshield washer hose and valves
- Design new battery cables
- JDM fan pigtail from 4Runner
- Add oil to turbo before starting
- Use old cats
- Install hood light
- Install new charcoal canister
- Adjust belts to spec
- Drain block and flush, a lot
- Toyota red and distilled
- Install Derale trans cooler
- Pick up ATF
- Fill up Mobile 1 DTE for steering
- Install new PS banjo
- Pick up silicone hoses Monday
- Get intake all hooked up with couplers
- Cover the throttle and cruise cables
- Change oil
- Install oil pressure hose
- Install new dipstick and tube
- TB cap
- Fix heater cable
- Boost and EGT gauge- decide
- Need clamps for small water pipe and FPR fuel hose
- Install lava blanket
- Mount meth tank
- Decide on meth pump location
- Wire in York manifold
- Mount OBA filter
How the hell are you going to zinc plate all that?
The zinc plated cats I think will really set this off.![]()
