Wiring questions? EzWire experts
Fresno, CA
Ok guys almost finished up my FJ but have some questions kinda have an idea of what to do but don't want to jack something up and have cuts in ym nice new harness.
For headlight switch have one hot do i need to then add leads and splice them into the harness for dash lights and headlights etc? there is no headlight, sidemarker etc lead in my dash harness so i assume i need to tap into the leads and the hot to the switch will directly power those leads.
Brake lights i have leads which i assume go to my brake switch but where do they go from there, i'm about to put a pressure tap into my brake line to activate the brake lights but didn't know if theres another way to do it.
Believe me i've searched and although not brilliant in the electrical department i've been able to make my taurus fan work and my wipers work off the GM column so i'm doing good so far. Quick help would be appriciated i have my DMV inspection on monday to get this thing back on the road so needless to say i'm motivated. Thanks
i do already have a wiring diagram for the fj and one for a camaro they just dont seem to be answering my questions
headlight switch is cruiser, i've posted here only a couple times and been able to get my questions answered. My FJ was in a fire almost completely burnt and i'm rebuilding i had no stock switches or wiring or anything to go off of, i only have most accessories with a few leads that were attached as i purchased things off ebay,here,or pirate. Because my vehicle was in a fire and insurance paid me i have to get a dmv inspection these two questions are all i have, i don't care what runs the circuits and i'll buy whatever it takes but as far as me having everything from a stock FJ that works and is wired thats a negative. I never try to do more work then necessary especially if it's electrical, mechanical=fun electrical=balding
Sorry, I don't know what you have and what you are trying to accomplish. If the cruiser is mostly stock, I would get a good used harness and switches. If it has a GM engine and you want to run a GM steering column, I would get a GM harness, lights, etc and wire it up like a GM truck. The hard part is if you want part GM and part Toyota. Then you will need to read schematics and understand them. For example the GM and Toy turn signals and brake lights are completely different.
ok i didn't really explain i guess in the first post, i have a gm engine and steering column, everything else in the vehicle is wired besides the headlight switch and brake lights. I have a stock fj40 brake light switch but i'll be damned if i know how to use it with the ez wire wiring. Headlight switch is fj though i believe mid 70's and i don't know if i need to splice into the ezwire headlight,dash,sidemarker etc wires because i believe since they have leads to all those wires there must be a better way, they just have no dash leads to go to the damn switch:mad:. guess they only care about chevy owners.
Nothing besides those above have i had any trouble wiring, at least not with the search button on several websites.
Nothing in this FJ is stock and i don't know the year to many accessories but i've wired most of them just need help here.
As far as wiring diagrams i have a diagram from my year column, a chevy truck, and several years diagrams. I cant figure it out from them, this question is best answered by an ez-wire expert into a 40 as ez wire has been unhelpful.
Realy need help bad this thing needs to be perfect for the DMV, i don't need any possible problems.
Pin_Head thanks for your responses i do appreciate any help
The EZ is pretty generic: just a fuse block and wire and a few odds and ends.
For headlights, run the wire from the EZ headlight fuse to the common side of the cruiser light switch. Wire other side of the switch to the headlights and the side markers/running lights. They are separate connections on the switch. The dimmer side of the switch runs the dash lights. If you don't know which connection is which on the switch, you can figure it out with an ohm meter.
Skip the pressure switch and use the cruiser one. This circuit is drop dead simple. Run the stop light EZ fuse wire to one side of the switch. Run the other side to the stop lights.
For turn signals, the easy thing to do would be to just use the 3 turn signal switch wires on the GM column. These are the center wire and the L and R wires. If you still have the cruiser hazard switch, then run the EZ turn fuse wire to the hazard switch lug that has the green wire with red stripe (remove original wire). Run another wire from the brake fuse (its always hot; the turn only works with the key on) to the green wire with white stripe (and disconnect or remove the original wire.) The green light blue wire from either the flasher or the hazard goes to the center pole of the turn switch in the column. The left side of the switch connects to the green/blue stripe wire cruiser that originally went to all the left turn bulbs. (or run new wires). The right side of the switch goes to the green/yelow stripe wire (or run a new wire to the right hand lights).
If you don't have the cruiser hazard, just run the turn signal fuse to the flasher and the other side of the flasher to the center pole of the switch.
If you want to run a GM hazard, wire it just like the whole GM turn-hazard circuit and use all GM parts.
