So i saved a 97 FJ80 from the salvage yard. It had been stolen from a friend then recovered. I believe they were going to part it out as they hacked the wire harness near every major component under the hood. Two weeks in i have a running and driving FJ except .... headlights. ive double checked all of the connections i made. If the relay is plugged in it will buzz with a low sound and the headlights will stay on. if i unplug the EA1 connector next to the fuse box the red wire with the white stripe is what is supposed to send signal to the relay " a ground" to turn on the relay and pass power to the lights. This circuit has nothing when unplugged one either side but when its plunged in.. its got a weak ground. I have unplugged the multi function switch no difference.
The relay is wired strange it had a large positive and a jumper that runs to the signal side of the relay? so, i guess a ground closes the relay and turns the lights on?
I have been fighting this for days and just cant wrap my head around it..
in a nut shell, with the ea1 connector unplugged, lights are off and there is no signal.
plug it in.. there is a weak ground and the relay has a buzz , the lights are on dim.
if you unplug the multi function light switch no change..
Anyone battled this before?
