wiring nightmare
Something like that. There aren't that many possibilities, so you can try the other ones if that one doesn't work.
P = IV, so 2V = 2P when I is constant.
But if you double the voltage, the current isn't constant, it doubles too. The only thing constant is the resistance of the primary. P=I^2*R or V^2/R Either way you figure it, the power goes up by 4. But agree that it would probably be bad for both the points and the coil.
okay. Im just trying to get spark, any spark from the coil, once that happens, then i will introduce the igniter and ballast resistor into the system. i have the start wire going directly to the solenoid. i have the black/yellow wire going from the ign to the + side of the coil, and a wire going from - coil side to dizzy. should i not get some kind of spark without the ignitor or ballast resistor?
Test your coil to see if can make a spark:
Disconnect the wires at the screw terminals. Run a wire from the + terminal to the battery +. Momentarily ground the - side of the coil (don't hold this ground wire in your bare fingers!) When you ground the - and let off, it should make a spark that can jump across 1/4 inch or more.
Once you know if the coil is good, then you can start adding things like the points and wire from the key to check them.
:bang:okay, i tried that, and the only thing that sparked was the wire that i used to momentarily ground the - side of the coil........question, does the coil itself need to be grounded while doing this? i just have it standing on the fender apron while doing this....
The body of the coil doesn't need to be grounded. You should get a spark from the high tension wire from the coil to ground. If you don't get a spark when properly performing that basic test, you've got a dead coil.
okay ,after buying a new accel coil, running a jumper from battery+ to coil+ and then momentarily grounding out coil-, i get an extremely weak spark to the block from the ht coil wire. you almost cant see the darn thing. so now i will wire it to the vehicle with ignition key start wire to coil+ and a wire from coil- to the dizzy. then adjust the points gap until i get maximum spark. is this correct???
When you grounded the coil neg, did you do it to the battery ground or the engine or frame? You should get a solid spark. You could have a bad ground cable in there on top of everything else.
You should adjust the points gap to spec.
i tried grounding it both ways, no difference. could it be because the coil is new, it doesnt have any built up capacitance?
Nope. This is not a capacitive discharge system. Just old school coil. Induced voltage from collapsing magnetic field.
