Wiring momentary switch and regular switch together
Maryland
I want to wire up my linelock with a momentary switch and a regular on off switch and don't know how to wire it properly. I want to be able to use the momentary and regular switch independent of one another. By independent I mean I can press the brake pedal and either use the momentary or the regular switch to activate the linelock. Momentary while wheeling or switch to hold truck for short periods. Below is a crude drawing. Would one of you electrical gurus please connect the lines? I just realized I left the power source out of the drawing. :doh:
oops,,,, both switches will share the same wire to the linelock just as they will share a common power wire, but i think the only way will be to use one-way resistors with them both. i dont know which ones to tell you to get cuz im not real good with wiring.
I am putting the momentary on my shifter for easy access while wheeling and the regular switch will reside in the dash and be used more for parking situations. And before anyone mentions it, yes I have a working mechanical parking brake I use.
Someone please tell me if my new sketch above will work or not. I think it will but don't want to screw up the line lock by hooking it up wrong. While doubtful, I have released the magic smoke from plenty of electrical devices in the past.
*edit*
Based on rustly_tlc's picture I think I have it right. Headed out to the garage to wire it up now.
Thanks!
I would probably put a diode between each switch and the line lock. Just in case there is any feedback
No diodes will be necessary. Just connect the two terminals from the spst momentary switch to the two (switched) teminals of the spst switch on your dash. The momentary switch will have no effect when the dash switch is closed , as the line locks will be engaged anyways. When the dash switch is open, the line locks will engage for as long as you hold the momentary switch closed.
rusty_tlc said:
I don't understand?
Diodes are devices that only let the juice flow in one direction.
Kind of like a check valve in hydraulics.
You would use that if you wanted to do multiple things from multiple switches. For example, if you wanted to turn on your linelock and the radio with the rocker switch , and just the linelock with the momentary switch, you could run in to problems when turning on the momentary switch. A diode could be used to isolate the outputs, but using a double throw switch might be better.
Anyway, both of the drawings look good, and in this case I wouldn't worry about isolating the ouputs.
Thanks.
I was really just wondering why you would need diodes in that circuit.
The only thing I could see that the diode would do is keep the dash switch LED light from lighting up when the momentary is pushed. That's if the LED shares the same points in the switch.I would rather have the light on anytime the circuit is made when either switch is closed. Kind of like a built in trouble light. If either switch doesn't close the light won't come on if that is the only switch closed and if points in either switch burn close the light stay on.
John
