Wiring help
Mt Juliet, TN
Before I tear something up, can someone tell me what I'm doing wrong. I am trying to wire elockers into my truck and I cannot get the wire splices to fully seat in the housing. They are part # 82998-12330 going into the ID1 connector in the drivers kick panel. They get about halfway in an hit something solid. Any tips are appreciated. Thanks.
Most of the Toyota connectors require that you slide out a plastic piece before you remove or install pins.
I think the EWD has images showing how.
It is basically a piece that comes out about half way. If you're removing a pin, you still have to press a release "catch" to get it out.
As blkprj80 said, make sure to lift up on the retaining clip first
