Wiring help....needs to blink
WASHINGTON...THE STATE
What I am doing is reassembling (1968 FJ40 with a '78 2F, the wire loom is the '68), but I'm having problem with getting the turns and flashers to blink. After reading thru old posts the last 3 days....proper ground seemed to be the problem the majority time....older lights, block junctions. I have all new lights, including new Led DRL headight from @Racer65 and to along with them some new flasher kits from @Coolerman to help handle the LED's.
Turn/Hazard (LED) Flasher Relay Kit
Part# FLEDKit-C This flasher kit allows you to add a flasher to your FJ40 that will flash your OEM incandescent bulbs even if the bulbs are the wrong type or have questionable grounds (you have to have them grounded properly to work of course). It will also flash ALL LED bulbs. On top of that, it has the clicking sound like the OEM relay so you can hear it. This kit comes with the LED flasher relay and the SH-ADP2 harness adapter to allow plug and play installation into your FJ40.
To add to my confusion, I have also added a tilt steering column (GM style), and I'm not totally sure of the connections between the two. What I do have are the headlights working, even with the floor dimmer....with the ignition on Also with the ignition on, and flipping the turn signal, the lights all come on (including dash lights and DRL turn) for the correct side, left and then right......but no blinking. With the ignition off, and turning on the column hazard, all the correct lights come on...except no blinking. I have two of the red knob hazard switches and have tried both....not sure how to verify the switch is good
What I don't have is brake lights ....and that is one of the column connections that I'm not sure of. You can see on the attachment, there are 3 wires that I have blank, but have tried inserting 12V power (both hot & ign. on)....but no blinking. Also with the turn lights on, I walked around and added extra ground wires to all 4 corners....still no blink.
Any thoughts or suggestion would be appreciated...........THANKS
I have no experience with LED taillights/turn signals... nor do I have experience with a ‘68 harness.
But, with incandescents, there are times (like wiring trailer lights (oh, so I did deal with LED trailer lights, from my 40) when I had to use a 3–to-2-wire converter or a 2-to-3-wire converter, depending on which way I was going.
Here’s a 3-to-2
Perhaps. You need to convert the signal, in order to “break” the taillight hot feed, to allow the turn signals to blink...
Maybe @Coolerman can shed light...
Thanks Danny...that did cross my mind about a converter, in fact I saved Mark's @Coolerman recommendation back a while ago about converters he uses....
Yes I usually recommend a powered converter. Curt has an updated water proof version they recently came out with that I have started using in my tow harness kits. Part # 56496. This is a bare bones kit.
They make the #59236 that has hook up wire and such included for those that may not have wire and splice taps laying around.
Both are overload protected so it you accidentally short something, they will not fry your vehicle wiring.
I think that would help with the brake lights??? As far as the turn signals not flashing, again reading thru Mark's past comments he mentions low battery and amps.....I'll double check all that, maybe the trickle charge on the battery is not enough, with all the attempts on the lights.
Paul
Putting a GM column into an early FJ40 is a little more complicated than just hooking up the 4 wires from the lights.
Your 1968 FJ40 wiring harness uses TWO separate flashers that also have to be connected to the GM column. One for the Hazards lights, and one for the turn signals. (So you will need two LED flasher kits.)
Next you have to wire the brake light switch through the GM column switch.
You have the 4 lights connected correctly, but you don't have either of the flashers connected, nor the brake light switch.
FYI the GR Horn wire should be coming from the S terminal of the OEM horn relay. This is the wire the went to the horn button on the OEM column. GROUNDING that wire makes the horn blow. This is how it should be connected.
