Wiring Harness suggestions
Have a 1979 FJ 40 that I'm doing a 350 conversion. The engine is already in and I ran the fuel lines for the carb and everything this weekend. My biggest pain is I bought this project from another individual and they had already disconnected most of the wires and didn't label them.
I've got the wiring diagram and it's not that much help. I have the haynes manual and really doesn't make much sense to me. Most of the harness is up under the dash.
But what I'm not sure of are things like where are the 4 ignition wires. What wire is it that should be ran to the battery.
I was going to take it to somebody to get it done but I'm sure they will charge a day or two worth of labor. As mentioned, I'm sure I could get a test light and sit down and try to figure out everything but I've ready where others have spent 3 or 4 weekends doing this and I've other things I'd rather do than trying to figure out the old wiring harness. Plus I've never messed with ignition wiring so I'm not certain about how to run the wires. Meaning, should I have a fuseable link from the battery into the 12v wire in the ignition and then the acc/on wires to one wiring block and then a straigth wire from the ignition start wire to the starter. Or should I have one or all of them to a fuse box, then to a wiring block etc. Where to tie the distributor wire into. The voltage regulater wire from the alternator.
With that said, I'm contemplating on looking into something like the ez wiring harness. I'm looking for an avenue that is labeled or intuitive enough to where I can get the wiring knocked out in a weekend.
Or conversely, if I'm missing something and there is a wiring diagram for the FJ 40 that gives you the color codes of the stock wiring harness walks things such as how to trace the 4 ignition wires through to the end of the wiring harness then I'd welcome that as well. Right now, I see the plug on the steering column and have found it's mate but without taking a knife and cuttiong all the sheathing around the wires, I don't have a clue as to where the where the wires are on the other end.
If an OEM harness is the recommendation, any thoughts about the ez wiring kit? Recommendations for others? I'm looking at the ez wiring because of the pricing.
Thanks.
I know there were some wiring diagrams on here in the past. However, I was paying more attention to the 1970 models. I had to replace my wiring harness; it was a bitch of a job. I also was in somewhat of a similar situation you are in, as when I took apart the cruiser, I took ALL of the harness out as well - nothing to go by.
I bought the EZ wiring harness; I think the 21 or 24 circuit one. However, the title is very deceiving as it's not easy. How much of the original harness is left? Is everything in the cab hooked up, and just the engine part left in shambles? Either way, it is nice to have a new wiring harness and know that you're not going to have a short sooner rather than later. I'd replace the whole thing...
IF some of the harness is already hooked up then you can hook the new harness up kind of as you go - matching the circuits *sort of*. I've read a lot on here and it seems most people go with painless, or EZ, either will work.
Best of luck.
There's no real secret to wiring, you have to break it down, do one thing at a time. I mostly used the wiring diagram that was in the Haynes manual, highlighted the circuit I was working on - completed it one little wire at a time. Hopefully this helps a little, I’m sure someone more knowledgeable will give you more advice.
have you thought of getting a painless wiring harness. They could probably get you exactly what you need for around $300. Then it will be clean easy and is probably still less than paying a shop to do it.
I bought the Centech kit and seems nice. I haven't installed it as of yet so I cant tell you how easy it is. You call them and tell them exactly what you need. They are really set up to go with the Chevy goodies on them like the right plug ends for the steering columns. Good luck.:beer:
You can figure out what the wires are and where they go by their location and their color code. Look up the color code on the factory wiring diagram. For example, the switched ignition wire is black with a yellow stripe that ends at the passenger side fender. The main chassis power feed at the battery is a large gauge white wire that ends at a fusible link at the battery. Reading the factory wiring diagram is a lot easier and cheaper than a new wiring harness and the after market harnesses are incompatible with the brake and turn signal circuits of later cruisers.
Yeah, I'd definately take another look at the Haynes manual. In there, they have the color codes on the wires. It will have a two letter code on the wire telling you the color.
I am on the home stretch of installing my Painless harness, and it isn't too bad. If you decide to go that route, just take your time and go circuit by circuit, wire by wire. It's taken me about 3 full days and for the amount or wire replacing, I don't think that's too bad.
Either way, good luck... I know it's a hard job to muster the courage to start.
-Mike
brake and signal switches
Why exactly are they incompatible...whats the cause, and what can be done about it.
Painless harness is $370 12 circuit. Also has labeled wire.
Ez harness is $165 21 circuit.
Neither are easily compatible with the toyota column, but can be done.
Thanks everyone for all the helpful info. I'm ok with wiring. I've wiring up building garages as well as my vehicles for trailering. Some of the post here have made it easier to just purchase a OEM. (I chose to try the ez wiring 21 circuit for price alone and they answered a lot of my questions.)
The main factor was all the wires I have were laying in the floor board and still some up under the dash. Somebody mentioned a white wire with fusible link that goes to the battery which I don't have.
I'm going to try this a hybrid way. First I just want to get my ignition hooked up and my engine started. Then I'm going to take the old harness and have it on stand by. When I run into places for connectors, I'm going to look at cutting the ends off and mating them up with the new harness.
I just wanted to make sure there wasn't a trick I was missing with the existing harness. But now I think some of the wires I've been chasing are missing so that makes the decision a lot easier. Plus now thinking about it, I'd prefer the new blade fuses over the existing fuse box anyway.
Thanks again!!!!
