I did a TON of reading here and on the MADelectrical website, and I could not find a good discussion on what SIZE wire I need to use for certain systems (from relays to headlights, heater, elec fan, accessories, etc), what amps these wire sizes are rated for, etc
I'm especially wondering what wire size to use to run from the 94-amp 12si alt to a separate, new fuse panel such as the Blue Sea 5015. it's a 6-position panel (I think), with a common power bus to all fuse positions. If I power this off the alternator, assuming all 6 circuits are "on" and using 20 amps each, what size wire should I use from the alternator to power it, and what size wire should I use to T-off from this to the battery?
Also, the MADelectrical site was invaluable as an education tool, but it appears to be inactive; where can a guy get fusible links like those shown on the site, in lieu of using a fuse panel like the one I've mentioned?
