Wire harness compatability
Cruiserdrew
On the way there
Sacramento, CA
A question about the wiring harness on a 40.
My 76 harness is in pretty rough shape due to an engine fire I had 4 years ago. It works, but the main harness in the engine bay is all glued together.
There is a 79 harness for sale that looks to be in pretty good shape. Does anyone know if these are similar enough to work? Appreciate any responses-I want good electrical for my rebuild (76 motor/body on 71 frame)
I have hesitated about the aftermarket wire harnesses, but if anyone has had an exceptionally easy time with one, please post up the details.
I guess that I would post up looking for a harness for the year that you want. The connectors feeding the rear section of the harness are not the same on a 1979, so it would not plug into your rear section of harness, and if you purchase the rear harness section from the 1979, your tail lamp assemblies will have different connectors on them and not be compatible with the 1979 harness without splicing the connectors....
I did the Painless Standard GM 12 Circit hotrod harness...Ive never done wiring before...other than typical audio stuff. Really...looking back on it, it was the most headache, but really not too bad...now that I have a general idea of wiring, I would buy and install painless anyday. It was about a 4 day project....first two days we spent about 8hrs each, and then maybe the other two were 4hrs each. Compatability wise I have aftermarket gauges so that was easy, but the rear lighs were a breeze and same with the brake light etc...(anything going from toyota to GM just took some testing but wasnt that hard to figure out.)
Hope this helps ease your worrys about aftermarket
The engine compartment is a relatively small part of the harness. I would just get some new wire and replace the burned parts. Gluing or shrink wrapping a piece of the old color code insulation on the new wire ends will help the next owner keep things straight.
