Wire clip broken, need help identifying it
Baton Rouge, LA
Does anyone know what this wire is and if clips are available to replace it? I broke the clip while removing the top bolt of the power steering pump. It’s just to the upper left of the oil filter on a left hand drive 96 LX450.
Should find the answer here:
Perfect, thanks! Its the coolant temp sensor for the dash gauge.
Would any of you guys be able to take a pic of the number on that sensor clip? Mine was broken and mangled when I broke it off…need the item number to get a replacement from Toyota. They don’t have that part identified in the parts graphic at the dealership.
