As others have mentioned:
1. Pull the fuse and make sure it is good. The answer to a bad fuse is obvious.
2. Pull the motor cover and disconnect the plug. There should be power to only one terminal on the vehicle-side plug (ignition switch in accessories position and fuse reinstalled, of course). This power does not pass through the wiper switch, so if you don't have power to one terminal, you need to find out why. I don't know about an '80, but there is another wiper plug under the dash near the glove box in mid-70s models.
3. Check the other terminals to ground at various wiper switch positions (the wiper switch does not apply power to the motor, but rather completes the motor circuit to ground). Note: Ignition switch can be off for this, so you don't inadvertantly blow the fuse trying to make these checks. One of the terminals should be grounded with the switch in the high speed position, one should be grounded with the switch in the low speed position, and the last will probably be open to ground but have continuity to whichever is the low speed terminal with the switch in the off position. If these checks fail, you need to check the wiper switch or the other wiper plug under the dash. I believe that new wiper switches are still available. The wiper switches can be taken apart and repaired, but personally I'd just replace it if it is faulty.
4. If the above checks are good, your motor is probably at fault. You can take it apart pretty easily to check the brushes (with a lot of use, they wear down and become too short to function). Did the wipers act slow and fail to run intermittently prior to finally quitting for good (signs of brushes getting short)? You can also still, I think, buy this model of wiper motor new. It'll be pricey, though. They can be found used, also, but the condition will be questionable. I have the part number for brushes that can be modified to repair these motors if you need to go that way. Just pm me.
Todd Bull.
