Wiper motor linkage
Holly Springs, NC
My wiper motor was starting to act up. Both intermittent and low would work only about 20% of the time. High worked every time but running high just to get light drizzle off the windshield is pretty frustrating. I purchased a new wiper motor replacement from rockauto. My linkages are good so it was just a matter of replacing the old with the new.
In the process of pulling the motor from the linkage, the linkage boot got destroyed. The rubber boot, although flexable, tore at the slightest touch. Now the end of the linkage is completely exposed. I've already searched both the forums and google looking for a part number other than the entire linkage. I've already started considering some really ugly DIY solutions for replacing/fixing/covering the boot.
Lq1tc2AfJ9kD-wZo_tpkZPwQ13JNPtWr8LrnnUng0dVYeSpJW5TlxQkuryHsCfg6NaDq45ExiSOrte1lpCT0_ZPdtTD7ZuOUYUgnMr-8STC20WlutE4jRE7zqDEbA58drOs5Cia_wNpBOCEZmH7F5umHx1FQGiQpIf0YS417BsOqK8ayhWErBJ1qYgyfExtvffzzXfUy993BP-J0Cd1WhIrJ_LlyI4s-FKsQ2CHacJOcFWRdr1cuu_kcgmm0UunN0JDxYxAtHeSa62f9wWEsCtjiKLgtwz8pMPdaBzkTCpsXm2RWcyt-o44IFp9BbhaZ7SzBM_gIJpPSzP4eSa67gfdANIFvBmQCcpdiGMjIxWoHJp2Jhb-cDjooyuAblD2CcdBCfkVQl2smRNn9JN_dyuU89ed35WSpj3-rQED7ENSjQRBN3zQHg_3RWg_c_ijEYhIASvw8qJ-qZEdV7BJU8SHCdc7HVoqQN_jcRgVm7KqQmgigs52aVzH7QKo7ub7yi6K1bmUPvBjtKHpbu7TxJVlI584-qdFs_EJCWfgemVYOnhOGCdHDj3YtNFkdyBBZZie3rTqSFt65BZ7dFQb_SdG9SWZeNZVXcpEaq2l3=w1856-h902-no
I don’t see a separate boot.
Looks like you still have the plastic washer that snugs down the end cap, if its gone, there is a nylon washer in the drawer parts at Ace Hardware.
part # 59563-Q , a 7/64 washer,seems like 2mm, fit onto the original socket as the lock washer.
those boot covers for the wiper arm spindle, they crack easily, and let water drain down into the armature. You should regrease those if you are going to be in there....
I fixed my rubber boot for cheap. I cut the middle finger from a thick latex glove and wrapped it over the linkage with a zip tie. I filled the "finger" with grease and installed the new wiper motor.
G7un5-0XNymZGsrVLP3a53OSPy4FqqHS22ViBakQ_1HbPOZyojH19IpqjfV-Ay4f0fhwHTkbjZzJO0f-4sxwdreL96bB2Lwijyld1WHPqHcLUBrR_ukuRDYNrNoXQVnIY4V6oekcyXaifHtTCRMqxmIZBW9cL5ghaheHdRV_sI2KyLkzinZTouc_YrQlQvQWxKgJ-suA5Ys4O91OU9OM5JOhQwgevfZyTZfMpoFV2XA4MCaq1kQhfliOKBFHv4s2JMzoeZ9W7EnWuK9enTDAOtxv42ItaKEu5hs56NgkRrH2fItD-B0_4P4Z-Uar7dmTUunmeOnnVkUcaT7RcQSXbubMkKWGsiYI8eINNmSHOur4jsllzjKWnlb15Dh9XgGWc2a0VyEz5A-RCZr3q_rhIniqbWpeEXmaGG_9Iagz16bV7rUn_8A15_BRA7cYteEtGdPb6Jz0wmKa5YNU-SLuyhUNrHz23u207inXwVsRGKptzcrF7Jb-Fx-SEaMRTiOtYbZ4BRaZbLRvZ3UDvqhlz0u0gmQ9yMXXNkWGvERzlhIRvZQBsWaB2b2er3Jz80K5ATeAS1Ke9VAA-PwL2occlrAyKlPog9rqyBS51WND=w492-h1012-no
3GqcmJMDFv3az0tDmtJXjzq3fqskEH6zevbE5D8rB2QmsvDDydqKGYvEBg3IBzq2X-s2BnRETXWi4UcHWh6IWB9dU4WWZZ2HtfZE3Na0erZCdr_E1iSPEs30kIkyGPtArujT19V4TjrUrSR-eDkEYOqZZPfpnk2cF9ePczwaR-o4Rr3kZ5NOVDaU9Mx4KNCtriFd6xLGa9UYUHHItE-T_lhED8K4wTx71DTfTR0DOWqJD3VCcl3VFnlKbrOVAoe8OUYoWw6rLtnp2UtWoZUL4FDaT-EAbzkW3-0UBRt3aMF0HhPSqaNASAkJGzsbeQwvITB6qBxumvn0j4F0OO4hiQW4trWp2LQwiwVLhwJlZGNsxcsej1jaznWMmrz4OwX5BQ5FA-972XmxyI4pBtKpvwCNTCuySSLYJqlSfofwRT6ojvRDGLDq79GPFTro8N8CWv-Mzk47UQqix7SiI6YvaP1ULPQNXYYR6_Eo-0fRTMBF-aUs4_6OHdSkQfxmqMVwV012CvSSthLgdk1ISt6WKEinwCSvbCxxYZia8zaIsgxgPxsMKGu6rQ1LWTyxMZoh_6Sl7tOXMLKmfvgX1RH2CgoOpJRKUX1q4hGrLyl1=w492-h1012-no
