Wiper motor differences
Southern Oregon
I just picked up a wiper motor. I understand that 78+ switched to a larger motor and requires a larger cover and drilling a couple of holes. My question is how do I tell the difference? I am using a windshield frame that has the lower wiper mount, but I have no idea what year it is.
a decent indication of when the change was made is to check for the windshield mount washer squirter-sometime in 1977 they changed IIRC. not sure if that was exactly when the change was made for the wiper motor but it might correspond.
EDIT: looking at SOR.com, it seems the changes happened at the same time.
So is the verdict:no squirters on the windshield frame is pre '77ish?
the wiper replcement motors you can buy are all the bigger motors. i bought one from CCOT and had to find a bigger cover, ended up getting one from SOR and just drilled the holes and mounted it, the motors mount the same no mods to the mount just the cover. good luck!
I have a frame, and a motor, I'm trying to determine which cover I need.
i just noticed the same thing . i have a 1975 40 .with a small cover .does not fit over the larger wiper motor . the PO drilled a hole in the end of the cover for part of the motor to stick threw and bolted the smaller cover on . i just put a 77 cover on it lined up with 2 of the holes just drilled 2 new holes and used self taping screws to secure the larger cover to the older frame .
ok Aalien i understand now, my large cover bolt hole center to bolt hole center measures 8 and 3/8 inches. hope that helps, if needed i can dig out my old small cover and measure.
That's exactly what I needed, thanks! Measused my stuff and both are the smaller setup.
Thanks again.
Aaland
