Wiper linkage DIY
New Zealand
When your wipers slow down check for slop in the pivot...
I used a 6.5 mm mauser case as a bush too repair my little pzj70 years ago and its still mint..... the 75 was a different bore and had plastic bushes ..they were toast and it was wearing away the casting. 6.5 and 357mag were abit thin but A browning 50 did the trick....the gap n the bush gets filled with grease after im done filing too fit.
Pzj has a smaller bore so i couldnt use my spare linkage bits.... the whole linkage was a different length too so i repaired the existing one.
6.5X55 is pretty common here in NZ.... the market was flooded with ex military m38/m96 unfired sweedish mausers way back in the late 80s...
Mines 120 years old and will still put 5 shots inside an inch and a half at 100mtrs ... Light too shoot , plenty of grunt and basic ..Ill never sell it , its all Ill ever need.
