Winter maintenance?
Philadelphia, PA
For those of you in the "cooler" states, what maintenance procedures do you do to get the FJ-40 ready for the cold?
This will be my first winter with my 1980. So far she starts up fast, doesnt over heat and runs real well. I am Rust Bulleting my under body this week end.
I will check the levels on all liquids, etc but should I think about a tune up if she is not due yet?
All that, and I switch to a lower viscosity oil for winter.
I would flush the whole antifreeze system: they tend to clog up eventually if you don't do it. Once a year is a good idea. And don't forget to open the engine block drain: if that isn't flushed, it will crud up too. Mine was crudded closed, and resulted in my #6 cylinder overheating and eventually burning my head gasket resulting in a leak and a tow.
On the F engine, driver's side, toward the rear of the block, down close to the oil pressure detector mechanism. Generally a square screw-in plug.
What is this exactly for and is it real important. I am also fairly new to the F myself.
The coolant travels around the engine block in what is called the water jacket. Just draining the radiator does not drain the engine block. This iron jacket is a great place for sediment to precipitate, and it doesn't flush out the top even if you run water through under pressure. I had 4 inches of sediment buildup at the bottom of my water jacket. The drain plug was plugged, and it took a day of digging to finally get flow to it. Needless to say, 4 inches of sediment means you don't get coolant flowing around the lower few inches of your cylinders, so you risk major difficulties.
Of the 4 F engines I checked, all were plugged to one extent or another, and a number of guys on this board checked theirs. Many of those were also plugged.
Opening up that drain and flushing is the way to keep your engine properly cooled.
i took my 250R and had the cylinder dipped in hot muratic acid for 24 hours... no problem! im going to do the same to my 2F..........
