Winter Intake Temp Question
Southern Maine
OK, so I read a bunch of threads on IAT's and didn't really find an answer. I understand that IAT is usually only an issue on pressurized intake engines, and that hotter air is less dense with correspondingly less oxygen. More bang in the motor equals more oomph at the wheels. Got it.
What I'm wondering is that how come when I'm driving to work this morning at 25 below zero, with air temps 130-140 degrees cooler than they are in the summer, that there is no corresponding power gain?
Is it a function of having more power but using it up pushing through denser air? Seems like you'd still notice a change at low speeds. Is it offset by drag from increased friction in the drivetrain from the cold oils and greases or maybe reduced tire temps? (That one I could buy given that the truck does seem to slow down faster in the cold.) Or is my built in 'butt dyno' just not sensitive enough to tell the difference in my normally aspirated rig but it actually is there nonetheless? Just too minor to feel?
Inquiring minds want to know!:confused:
The computer adjusts the amount of fuel based on the MASS of air. The air that is warmer and thinner gets less fuel per minute than the colder air, so your fuel/air ratios are constant.
Also, the burn of the fuel is less efficient at colder temps, so it takes more fuel to overcome the lower temps of the colder air.
Think about the choke on the old carbureted cars. You had to pull the choke to REDUCE the amount of airflow in order to INCREASE the fuel/air ratio in order to get ignition because there are less vapors at lower temperatures.
An no, IAT's are not only an issue on forced induction engines, as the fuel/air ratios need to be adjusted based on the IAT. That's why all the computer controlled vehicles have some form of Mass Arirflow Sensor and O2 sensors. They work in conjunction with each other to optimize the burn at multiple temperatures as well as elevations.
An increase in elevation REDUCES the mass of the air at the same temp than at sea level, so the fuel/air ration must be adjusted for optimum burn.
You'd only see the power gain if the engine was on a dyno, and then only because it was instrumented with sensors which are designed to observe/record the minute differences you're talking about. And that's only if it was tuned to original design specs.
On the road, you won't see anything; the differences are too small.
On the engine side of thinhs, there are a bunch of factors, but all things equal, it mainly has to do with specific output, which the 1FZ is very low on the scale: 47 hp/liter. If it had something like 120 hp/liter like a Honda S2000, you'd feel a difference.
Power to weight plays an equally important role.
I can definitely feel the difference in power in cold air vs hot. Its like a whole different engine in the winter! I will say that it does take a few minutes of driving to get the axles, trans and transfer case warmed up. But after that, watch out!
Huh. Completely missed that the 'mass' in the MAF would measure density as well as volume.
OK, now it makes sense! Thanks!:cheers:
On boosted rigs like mine, lower intake temps at the MAF seem to cause less knock at WOT than higher temps. The actual numbers are rather meaningless as actual intake temps post compressor are MUCH higher.
