WINDSHIELD WIPER
MT PLEASANT SC
Thanks to @Coolerman, for his wiper science 301, I was able to get my wiper motor working. At some point some PO had changed the wires in the motor plug to match the harness,makes sense but wrong. Had it not been for Marks detailed write-ups I would have probably never figured out that the LW and LB are switched at the motor plug. Up to this point all I could get was slow speed and no park.Now I have low,high and it parks.But now the high is on when the switch is half way out and low when it is all the way out. I tried switching the LW(low speed)wire and the LR(high speed)wire at the motor plug but that would blow the fuse. Any thoughts on this would be great,I tired of looking at blue wires. Thanks,Tommy
This is a pic of what kind of park switch I have.
Do you know what year wiring harness you have and if it matches the switch on the dash? Once you know these answers it will be a matter of comparing the wiring diagrams for the year of your motor, harness and switch to determine what needs to be adjusted.
Just built a new harness but followed the old 1976 harness for plug pin positions. Or should I say that's what I meant to do. I will check the switch when I get home. Thanks
