Windshield Wiper help - Part Numbers
Sacramento, California
Website
www.instagram.com
Hello there!
It's been a minute
I've been working on La Cabra getting her road worthy again. One thing that I need to fix is the windshield wipers fluid situation.
The pump is leaking. I changed it a while back with a Toyota original, but forgot to order the gasket. When I visit the Toyota site, the pictures show it as being 85330A. Having said that, when I search for that part number nothing comes up.
Then there's the valve that directs the fluid to the front or back. mine is done.... It leaks profusely. I'd like to replace it but I can't seem to find it on the Toyota parts site.
Do any of you have the current part numbers for these?
Regards
Alvaro
Are you referring to the Grommet or "Bush" for the hole in the fluid reservoir/tank where the motor pushes in?
The diverter valve is called a "Valve Sub-Assembly, Washer".
You can use Toyotapartsdeal or Partsouq to search for parts:
Here you go:
The diverter valve is called a "Valve Sub-Assembly, Washer" found under Washer or Rear Washer
Here you go:
Thank you so much!
Hello there!
It's been a minute
Regards
Alvaro
Has the diverter valve in stock if you still looking for one.
Similar question to the OP, I am trying to identify the grommet for the smaller hole in this picture? As the two bigger holes I assess to be 85330A?
