Windshield washer nozzles
Portland, OR
My Cruiser been involved in an accident in past (not on my watch). The hood had been replaced with aftermarket one and it lacks windshield washer holes. Whoever installed it didn't bother to do anything about it. I prefere to have them Can anyone measure locations of those nozzle (x, y) from a corner so to say. Any specific experience about such work?
I'd greatly appreciate it.
Thanks from long time learky here.
Oh an if any has a schematic of washer hose routing on the hood or would be kind enough to take a picture, hat's off.
Since your in KC there are a number of folks in the area you can take a peek at theirs. Go to the club section and find KS and make a contact.
Sorry to hear you have a cheezy hood. Aftermarket sheet metal is a hot button with me....:mad: Insurance co's like to f**k people by shoving that crap down their throats.
The nozzle holes are irregular in shape and are very difficult to duplicate. The "correct" method would be to go to an OEM hood and remove the nozzles. Then take a piece of butcher paper and lay it up on the hood and mark the hood edges. Then trace the nozzle openings on the paper and transfer your template over to the POS problem you are trying to solve. It will take the proper size drill bit and a small flat file to duplicate the holes in the aftermarket trash.
Do study the underside of the copy to make sure it has the correct crumple zones in the framework. It would be a shame if the vehicle were involved in a subsiquent accident and then have the hood shoved back through the windshield instead of folding up. The latter could cut someone in half.....
I understand that the shape is like. I just need location. My only real concern is to remove the hood for work or not. I'm thinking good support at the back while drilling large (about 1/2) in thin sheet metal could be good idea. Removing it by myself could be a bit awkward. I'll see if can fashion something using couple big welding magnets I've got.
I just told you the best way to establish that. You do not need to remove the hood, just pay attention to what is behind it when you start cutting.
I understand that. Problem is I don't have access to stock hood. Even if I contact some other owner, that would mean taking off sound insulation, taking out nozzles, which do get brittle over years (I learned that scouting local u-pull-it for some nozzles from Yotas of same vintage, not that easy, got to be careful), pulling hoses etc. Good chance to mess up somebody else's truck. If I get position within 1/2" it good enough. Hood is already not perfect, you know.
Appreciate advice though.
Second question.
Did anybody ever took apart combination switch or specifically wiper/washer switch. My story with nozzles don't end with hole cutting. The button on the tip of the switch is jammed on mine. I'm guessing it's "jammed" for a "reason". I don't see anything mechanically holding it together no screws, etc. Is it snapped together? Does it come apart? I know washer pump works since when I twist for rear washer it comes on.
Why don't you look into attaching sprayers to the wiper arms (like the late model Chevys use). Are there any Toyotas with this kind of washers? The sprayers on our work truck work much better than any hood mounted sprayers I've used.
I hate to be the voice of gloom, but you have what you got.
You have an aftermarket hood, and it has been painted.
You can take your chances and try to cut holes in the hood. If you do, you will make a hole in the paint where rust or discoloration can start. Or you can use any of a number of spray nozzles from a wide range of Japanese cars that are designed to reach through the louvers in the cowl area, and make them fit. Or, Windex makes a spray bottle that you can keep in the console to spray the windshield now and then!
Realistically, I saved my hood from a rollover and put my windshield sprayers back. Yet I rarely use them. Are they really so important that you would risk corrosion to have them? Gas stations everywhere have window cleaning abilities. You may be able to do without this feature.
When I had my first car at 16, my sprayers clogged up. I re-directed the squirters to spray out on the right side. I could squirt the people on the sidewalk as I drove by! That was kind of fun! Be creative!
I'm rather peculiar about being able to see. I can put up with lot of other nasties from the car but I got to see road in front of me clearly. I personally think it's serious safety issue. I'm not worried about rust. I think I can manage that. Doesn't get much worse than cutting 90mm hole in my fender for snorkel install I did on my Montero.
People please, anyone got a square or tape measure? All I need is measurement from back end of the hood to sprayer and then one from fender side of the hood.
OK, anyone in down town KC at daytime? I'll stop by.
Please. Appreciate any help.
GM w/s wipers
I agree with Trailbus I have started looking into this and it doesn't seem to hard if you go to a junk yard and pull the w/s wiper arms from a chevy truck with some of the hose so you can run it to the w/s wiper arms you get a much better result the only problem maybe the arm fitting the existing connection. I love GM's w/s wiper system :clap:
I know that this doesn't help, but if it were me, I would find an OEM hood in the same color and just deal with the difference in shades. This is a lot of work for a crappy result.
Good luck.
Ha, ha that funny. My crappy aftermarket hood was painted plain white not even close to original pain on apparently untouched in collision front fenders. I looked into getting hood but there is none available locally and shipping one would be darn expensive. Guess I can entertain GM wipers idea but I don't think it's going to be easier than drilling holes in hood.
The Kansas City Toyota PDC (11111 NW Airworld Drive, next to the airport) has two hoods in stock right now. Any metro KC dealer can drive over and pick one up today.
That would be $400 for hood + painting it + tax. Just to get washers. That's rather too much to my taste.
I was referring to buying matching used hood.
Man how hard can that be. :crybaby: A week ago I asked a friend in CA with LX450 to measure it for me. He falls of the face of the Earth. Like I asked him to measure you know what, not position of the sprayers :D.
Dang, there is not even a local dealer with LC 80 for sale to stop by. :bang:
Ok, guess I should have looked on autotrader I only checked cars.com. My bad. It is a bit ways out for me but something to consider.
Thank you.
I guess I just guesstimate location of those nozzles from pictures.
Another Idea
What you could do is..........................just kidding.
8.25" from the rear hood edge, 19.75" from the side, measured to the centerpoint on the rear edge of the sprayer.
Sorry if I ruined somebody's game.
