As has been stated already, it's the lack of urethane sealant that causes the leaks in the lower corners of our windshields. No glass shop will go this extra step so you'll need to slip the tech some $$ and then watch them do it. It's a PITA to do it, because they have to first apply the sealant to one side of the molding, install the glass inside the molding, then place the whole shebang in the hole, then apply the urethane from the outside. This is a very messy job and time consuming for an installer. I suggest having them come to your location, pay them the extra $$$ and then help them do the job the right way. Hell, give them a case of beer on top of the $$.
My daughter's BF used to work in a glass shop so he did this extra step and now no more leaks from the windshield corners. No more shimmy on rough roads either. With the previous windshield, I applied urethane around the entire perimeter of the glass on the outside, but it still didn't stop the leakage, but did stop the shimmy.
There are two side effects from not applying urethane in my experience: leaky corners and the glass will shimmy on rough roads during winter after the molding shrinks a tad from freezing temps. If you place a sharpie mark then drive on a rough/washboard road/trails, you can see the sharpie line move around!
I have a new leak that's dripping down from the blower housing then onto the floor, and I think it's coming from the giant fresh air cabin intake hole under the cowling so I'll need investigate this when we get a mondo rain event this coming weekend.
