Window switch electrical contacts
STL, MO / Middle USA
Has anyone tried using solder or an electric conducting epoxy to "refresh" worn contacts on widow switches? (or any other switches for that matter...)
I am planning on removing the master switch assembly on my '95 soon to do the auto-up mod & clean the contacts while I am in there.
Through searching, I have seen how many have had issues with contacts being worn, & repeated cleaning is infective. I thought this might be a possible solution. :idea:
The epoxy runs about $40 for two 14g tubes, which isn't super cheap, but would probably do a ton of contacts, and is also useful for it's intended purpose of being a heat-less solder. As far as regular electronics solder, I have it around anyway.
Thoughts, experiences, criticisms?
My windows all worked up and down until after I took the master switch apart. I cleaned it out with quick dry contact cleaner and lightly sanded the contacts using 1000 grit paper, put it back together. Now the DS rear window will not go up using the master switch. I had moved the worst looking (burned) rocker contacts to the rear assuming they had been on the front. Haven't pulled it back apart yet to look at it again however. IIRC someone once mentioned that the contacts are plated?? IDK.
Just buy new $55 at SwitchDoctor
I've got a 97 but I got "into" the switch mechanism and sanded and cleaned etc. Eventually, I realized that so many pieces were out of tolerance that the switch would never really work. First I got the $200 estimate, then I came across Switchdoctor and for under $60, I had new working switches. Nice. Take my advice on this one.
Ordered: 1 Shipped: 1 211 Toyota Land Cruiser 1996-1997 Window Master Control Switch $55.00 Ship Date:
Product Total: $55.00
Sales Tax: $0.00
Shipping: $3.00
Discount: $0.00
Surcharge: $0.00
Grand Total: $58.00
