Due to the clamp/track coming off the bottom of the passenger front window on a cross country road trip. I dove into the window issues. There are two bolts that connect the window clamp/track to the regulator. My OEM front door regulators was so worn and wobbly, I went ahead and replaced both the drivers and passenger side. Once you see how smooth a new regulator is compared to the OEM regulator, I think this is making your window rock and not go up level.
One lesson learned was not to remove so much of the plastic like I did on the passenger door. On the drivers door I just cut access holes exactly where I needed to get to the bolts and remove the OEM regulator. The large hole on the bottom for access to remove the regulator once unbolted, the exact spots where the window regulator bolts , and the oval hole to remove the forward 10MM clamp/track bolt from the regulator. When I was done, I gorilla taped the holes back up.
I also removed the windows on both sides. I removed the PO window tint and all the gunk from the edges of the windows that you can't see. I also took a putty knife wrapped shop towel and ran it in the track in the door as well.When I put it all back together, everything was smooth as much faster. I think physically removing the windows and cleaning the hidden running edge part of the key to having smooth operating windows. My window hidden edges had window tint on one side all the way to the edge of the glass and 25 years of gunk on the outside of the window. To remove the windows there's a couple good videos on youtube. They really go in starting at 45 degree angle or steeper to get the window set into the front and rear window tracks inside the door then level it out once inside the door. For safety I also added a rolled up towel in the bottom interior of the door just in case I dropped in putting it in.
If anyone wants to see a video comparing the wobbliness of the old regulator vs a new regulator PM me. I'll text them to you.
