I can only find doorman replacements for the front door windows, not the rear. Are they exactly the same? I need to replace all mine the motors are terrible, one of them doesn’t even work anymore.
Toyota still has them the last time I checked. Have you pulled them out and cleaned the motors? One of mine quit working I pulled it out an cleaned the dirt and grease off and it works great now.
The “window runs” may need replacing. With age they drag on the windows and cause them to appear to have faulty motors - and will in fact wear out the motors.
Before you get in hurry to whip out your wallet and spent alot of money you just might just want to follow the above advice. More then one Mud member who though his window regulators were bad, found out later that the real problem was his window runs.
I just inspected my drivers side window cause it had been clicking and making noises when going up. Found out that the outer piece of wi Dow ran tailing had come off. Tack welded it back on, removed my window run and cleaned it out. The real problem was the regulator itself. The two guide wheels were bad (seized and the hole was elongated causing them to drag). I’m ordering a new regulator and window runs for both fronts and I should be good to go. Super easy to remove and replace.
