Window or door seal nightmare
Hey everyone I am experiencing several issues with my 96lx and have done some searching but not certain I've got a definite answer to all. First up both front windows roll up slowly and have tons of wind noise even at 50mph could someone let me know specifically what seals need replaced to solve this?
Also when it rains I am getting large amounts of water in the front driver and passenger floor boards could this also be door / window seals or could it be the front windshield seal ? Please provide part numbers and install advice if possible or link me to it .
Thanks for any help
Windshields leak on most of these. There are many posts on replacing the seal If you search about this and problems people have had trying to solve It. Some members have found a qualified repair service to fix this issue. If you live where It rains you will need to find someone who knows what their doing. Its an old school repair. Good Luck...!!!
The most common source for wet floors is the drains on the sunroof being plugged. Search for that and you probably have your wet floor answer.
There are also several threads on slow windows that may help that issue.
I just checked the front sunroof drains both looked pretty clear, I poured some water down each side and watched it drain from the slots in the rocker panel . So thinking those are ok. It's still on the factory windshield and visibly the gasket looks alright. It's pretty recently started taking on lots of water when it rains. Is there any other way to test besides pouring water over the windshield and watching
Close your sunroof and pour water on the corners of it, slowly, allowing it to pool. Then check and see how fast it drains into the tub, and whether or not all of it goes down the drain or runs between the headliner and outside of the sunroof tub.
