Window motor dead
Atlanta
New guy here...have a 93 FZJ with 245k miles. Not a daily driver any more, but love to drive it. Anyway currently have a drivers side window that won't move up (stuck down). Have had this issue intermittently for the last 6 months. Now it won't budge even after pounding on the door (which used to work). I cleaned the contacts in the door switch box hoping that would do the trick. No joy. So I guess I am down to replacing the motor. Anyone have any insight and/or a place with reasonably priced replacement motor?
Thanks
Ron
Mine is about to go too, same question. Thanks LC.
I'd either get a used one from one of the guys parting 80s or (depending on price) a new one from CDan.
I would make wure it is not the switch first, cleaning contacts does not necessarily do it, power the motor directly first.
motors are normally pretty tough. There's not much to go wrong in them, and when they do start to fail, they just start getting slooooooow, particularly when going up. Despite a helper spring on the regulator, it's still harder to push a window up than pull it down.
My bet would either be the contacts in the switch or the wiring harness in the door jamb. Sometimes cleaning the switch's internal parts is not enough. Quite often, the copper "rocker" ends get bent enough that they don't make contact anymore. Tweaking these just a bit has always been my fix. If you have a multimeter, you can see if the switch is getting power and if the motor is getting power.
Another distinct possibility is that the wire harness that runs between the door hinges has cracked. I recently fixed 3 wires on my mom's 94 Camry driver door. The harness itself looked fine becuase it was protected by electrical tape and a protective "jacket", but when I removed it and the tape, I found one of the wires completely broken and two nearly so. Many years of opening and closing the door takes it's toll on the wires at the door jamb because they are always being flexed.
If you have a multimeter, it will be very helpful in determining if power is getting all the way into the door and how far it gets.
on my 93, the rear passenger window goes 3/4 of the way up and stops. if i grab the window and push it all the way up, it doesn't stay up and drops down. where it stopped. either the regulator is worn out or something. let me know if you have the same problem.
Yours has jumped the track bro. Pull it apart and put the arm back in the track. You'll be good to go.
An "easy" test to see if the window motor is bad is to remove the door panel then disconnect the wires leading to the motor. Run a couple jumper wires to the motor from the battery. You just need to swap the wires on the battery to test both directions of the motor.
At least, the above worked for me. My problem turned out to be the switch.
I guess I need to pull out the multimeter and do some testing before buying a new motor. The window had been moving slowly when it did work and sometimes I had to pull the window up to get it moving. We'll see when I get back to work on it.
Thanks for the tips!
Ron
One of my rear windows wouldn't go up some time ago. The window had come out of the track...it took a hammer to knock the metal attachment on the bottom of the window back into position to not fall out of the track again.
