Window Issues w/ a Question
Gig Harbor, WA
I have just been inducted into the broken window club!!:doh:
I have read through the various posts (there are alot of them) on the window issue these rigs are inherently predisposed to -- slow going up.
BACKGROUND:
Mine has had a couple times over the last two years when it was slow (usually cold weather) but today mine went down and would not come up. Temp was about 38F and light rain but warmed up during the day to approx. 58F and clear (info for you number crunchers)
SITUATION:
Put the window down this morning while coming through the front gate and the damn thing would not go up. Tried pulling over and cycling the ignition (remember reading this in a thread a while ago) and the window did go up (3") just enough for me to grab the top and try and move it up.
Pulled the switch panel during lunch, way dirty but all cleaned up now. Did the R/R and the switch works smoother but still no joy for putting the window up. Half way is about all I get. Applied silicone spray to the tracks -- this resulted in no help.
The local dealer said they could get the tracks sometime tommorow or the next day.
QUESTION:
When I was pulling on the window to assist the motor it seemed I have a bunch of play in the window -- I could literally move it from side to side and the window actually would move almost an inch up with the motor (freeplay). I looked at my passenger window and there was a little movement but nowhere near the driver's. Has anyone else experienced this and if so what was the final verdict on cause and the fix? I have read where a couple people tapped the rivets on the tracks but that was to free them up. I also remeber readin a post talking about tapping the window back into the frame (tried searching the posts again tonight to find it and cannot seem to recall which one or who posted it) -- not sure if the symptoms that led to this fix where like I am experiencing.
ATTEMPTED SOLUTION:
Cleaned the tracks, while installed, and reapplied grease. All the runners looked and/or felt good but I could not get my hand/arm in to verify all fittings. Did a cursory check of the 10mm bolts holding the track in the door and they seemed tight. Not sure what else to do and I do not have the luxury to pull the door apart tonight without parts and this is my DD so I cannot be without it during the week. Any help or suggestion would be appreciated.
Heres what I think has happened. On the bottom of the glass, is a 10 inch wide piece of metal, like a gutter, that the glass firmly pushes into. Mine fail, when the glass gets wedged, and I try to unroll the glass, the glass is stuck, the motor keeps pulling down, and can pull this piece off the glass. I also think this happens over time, causing the glass to be a little skewed in the track, causing it to bind and eventually fall/get pulled off. Your fix is to remove the panel, careful of any speaker BS. Peel the moisture barrier back, on your right, when looking at the guts of the door, get a hand in there and grab that piece that is likely sitting in your door sill as it has fallen off. You can, with the door panel unhooked and some power to the truck, still move the motor to the window, move it up and down and you will see it is a little wheel (blue color), that goes into the track on this metal piece, and then gets pushed back on to the window...fixed...if that is your problem, you slide the wheel back into the track (like a closet door) and then roll the window up via the motor, until the metal bar meets your glass, and then carefully push it back on...
fyi, clean the metal piece thoroughly, grease the wheel, clean the bottom edge of the glass, and the metal gutter will hang on better. It's a simple mechanism....
Also, when you are in there...you can see how the motor works, unconnected to the glass, to see if it is your switches or motor...
no fix w/out opening the door...me thinks
Jeff
Jeff,
Thanks for the quick reply. Once I got to my shop I cleared a portion of our bay and pulled in then got on Mud and did a quick search (luckily the boss is not a tool).
Found some of the things you mentioned. I actually pulled the door panel after I pulled the switch assembly. I followed a link in one of the write ups and dismantled the switch and cleaned it all up -- side note, I would not have pulled the terminal connector off the back of the switch this does not affect the disassmbly but make for a loner reassembly due to having to line all the pins together to reinsert.
I did not have the time during luch to disaasmble the whole system, just clean what I could and try new lube on the tracks and silicone on the run.
I will now wait for the dealer to call when the parts come in and then I will disassemble the door once again. I will look at the track for any seperation from the window. The runners in the regulator where good and seated inside the tracks.
When the window would not go up, was the motor turning or making any noise or was it not doing anything at all?
If the motor was turning or you heard a buzzing noise or anything of the like, the plastic gear inside the motor mechanism has stripped.
Brian,
I never hear my motors when they are running. Maybe I should pull it in and actually listen for it. I believe the motor os running because I got it to go up in small intervals but not one steady motion like it should.
When the window runs come in I will probably pull the regulator and tracks with the motor and do an R/R on them.
Just frustrating when the window doesn;t work and I have to put it down on a regular basis.
Glen
I picked up the new window chanel rubber today, was quoted £75 when i ordered it but it was £69 today, part no 68141-60010, whipped the old rubber out from the outside to save taking of the door card & cleaned the edge of the glass up, slid the new rubber down the front chanel ok ( by the mirror ) but the other side wouldn't go down the last couple of inches so had to whip the card off, while i was in there i thought i'd lube everything that moved up & noticed the nylon wheels that run in the guide were siezed & the bottom of the giude was full of water, SO i assume than when we have hard frosts this water freezes & this is what stops the windows from working, iv'e greased the guide up & now the window goes down like jordons draws, a little slower up but now very smoothe & no juddering, with the engine running it goes up quicker, so although the rubber's b****y expencive it DOES make a huge difference.
The same thing happened to me last week. I pulled the door panel and removed the window motor and the riser. I then unhooked and took the motor apart. The inside of the motor was filthy. I cleaned the motor out, plugged it back in and it worked. It was actually stronger than before. Replaced everything and the window went up, it may just be a temporary fix but I plan on doing this to all my windows in the spring.
iv'e greased the guide up & now the window goes down like jordons draws, a little slower up but now very smoothe & no juddering, with the engine running it goes up quicker, so although the rubber's b****y expensive it DOES make a huge difference.
I'd love to meet Jordon.
Yes, those window runs are bloody expensive, and I have no idea why !!!
Anyway, I just went through this same thing, new rubber window runs and outer wiper seals, cleaned and lubed all the mechanicals and cleaned and lubed the motor internals. The window runs much better than before, but I don't know that it's really as fast as when it came out of the factory. It still seems slow. I am suspicious that the spring on the regulator might lose some strength over time, but cannot think of a way to confirm that theory without getting a new regulator.
Any experience or thought on that?
