Window groove cleaning fluid?
Jefferson City TN
I read on here at some point about what to clean the window grooves with the help with the window speed. all 4 of my windows go up and down, but they are grimy and nasty in the grooves... Their was something that cleaned them up and made the window work a little better.
Silicon spray will help the rubber window runs, and a dry lube will help with the other guides. Are your door panels off? If not, just spray the silicone oil in the run and wipe off the excess from the window and overspray areas.
I used a steam cleaner on mine the other day. I had the door panels off to install some sound deadening... The steam sure did get all the crap out of the groove the glass slides in and the windows seem to move a little better now.. I'd say the first step is to clean the window runs out.. Degreaser probably works fine. Then put some silicone oil in there.
