Window channel help
Columbia South Carolina and Cedar Mountain NC
Im replacing the felt channel liners, not sure if that’s the correct term, for side door window on 1979 HJ45. OEM weatherstripping package does not have aluminum replacement. Was given foldable rubber felt except for the bottom window opening channel which is aluminum, although I need to cut that one piece to size.
Does anyone know a place I can get full aluminum felt lined inserts for the channels for the entire window opening as well as the inside door channel?
This is portion of remaining aluminum with a piece of replacement rubber as example. And the curved portion for top of window opening I would also like to replace.
