Wind Shield Gremlin
Charlotte, NC
So. Here is the situation. I have a 97 LX450 and back in December I had the windshield replaced due to some wind noise I was getting at the top of the wind shield.
After having the windshield replaced. And to my displeasure, and warning of possible failure to the installer, it was replaced without replacing the gasket.
Well, as I thought and all my research hear on MUD indicated. We established a leak in the driver side corner.
I had the installer come back and he attempted to seal it. This did not solve the problem.
So I ordered a gasket from CDan and had the installer come back out. This time I removed the cowling and all interior and exterior trim around the windshield.
He asked if he could try and seal it again, now that all the trim was off and out of the way. Against my better judgement I said yes.
Well 3rd time did not work either.
So now we are on our 4th attempt and he pulled the glass and used the new gasket.
Here is the problem now and why I am posting this.
It has been 3 days now and today it rained. Well I have a leak again. the only thing I can come up with is that the glass he used is not OEM or anything close.
Is it possible that the glass is a couple of mm thinner than factory glass. And due to this it is letting moisture weep around the glass?
I have not contacted the installer about this latest issue as of yet.
I am trying to come up with an idea of what the issue could be.
I offered him the FSM to look every time and he shrugged it off and said he didn't need it.
Any ideas here on MUD?
Thanks
the replacement windshield i had in the marshmallow wasn't oem and not a drop came through. it's was siliconed like crazy tho. if he doesn't want to look at what toyota says to do after 4 attempts to seal it, go somewhere else and make sure everyone you know also goes somewhere else.
Remove windshield. Use the silicone on the windshield edge and mount rubber. Then apply to steel frame and in rubber and install windshield.
Only way got mine sealed and ordered all parts from Toyota.
Where do you see the leak? Are you sure its the windshield and not the sunroof drains causing the leak?
Yes, I am sure it is the windshield. I sealed up the sunroof one day and taped up a garden hose just on the wind shield. It is most definitely the wind shield.
It is the bottom drivers side mostly. but now you can see the water gather across the bottom of the wind shield.
I had heard rumors of ppg glasses being mis sized 10 years ago but I always assumed length and width. Not thickness. Even if it was off a hair I'd guess a properly sealed gasket would make up for it
My first step was to go to 4-5 installers to find one that was willing to use FSM procedure. Did mine and Decemberuding CY (Chinese GM oem provider) with new oem gasket and all good so far.
Did they seal between glass and gasket AND between gasket and metal? most times it is a miss of one or the other.
Print out the FSM pages detailing the procedure, find an installer who claims to be willing to follow them, watch them the entire time, and be prepared for them to fight you like a 2 year old at bedtime when it comes to applying sealant to the gasket.
You are correct. I told them and tried to show them. That the FSM indicates no adhesive between the gasket and metal except at the bottom. This time they didn't put adhesive anywhere except at the bottom of the windshield, between the gasket and metal. This has been most frustrating. I could have done it wrong this many times and probably gotten it correct by now.
I was trusting the advice and recommendation of my friend and mechanic. He has done all the highly technical wrench turning on my vehicles for 15 years now. He has used this window guy for just as long. My mechanic buddy feels horrible about this entire scenario. He is very embarrassed that someone would not use the FSM when it is provided to them by the customer. I am glad that I ordered the gasket fro CDan and did not let the glass guy get some crap non - OEM one.
That could be the problem, I took the FSM instructions to seal all the way around between metal and rubber, as it shows the masking tape goes all the way around both sides. I sealed all around (glass to gasket, gasket to metal) and has bee perfectly dry since.
