Winching Questions
Farmington, NM
Hello,
I recently acquired the shortbus bumper at Cruise Moab so I am researching winches. I know the choice of a winch is a personal one depending on use but I developed a few other questions.
1. When you double the line with a pulley and use an extension does your extension need to be rated for 2X the pull of your winch? So using a M8000, doubling to 16000 (I know only on the first wrap), the extension should be rated to over 16K right?
Does the winch line need to be rated 2X the pull since it pivots on the pulley at a single point?
2. What is the "usual" winch line distance for someone in my area? NM, CO, AZ, UT. Just thinking about how much synthetic line to get to maximize a winch to the first wrap and to save money and just get an extension for longer pull distances.
3. Since I am using synthetic line and most say to keep one wrap on the drum to avoid pulling the line off, should I just start looking at second wrap ratings for winches instead of first wrap?
Thanks for answering my mundane questions,
TR
Winching
Ok here we go.
Your winch can pull 8000 on the first wrap. Using a snatchblock you can get 16000 at the eye atachment of the snatchblock. Everything from the snatchblock to the casualty needs to be rated for 16000. Everyhing from the winch to the anchor for the winch rope end need to be rated to 8000. A point to be aware of is if you run the hook end back to your vehicle you will be anchoring the whole 16000 and if the casualty is really stuck you will probably drag your vehicle towards it. Better to anchor the hook end to a solid achor point like a good tree of another similar vehicle.
Check out the information here at this link.
http://www.pirate4x4.com/tech/billavista/Recovery/index.html
And this link
http://www.pirate4x4.com/tech/billavista/Recovery/US Army driving manual vehicle recovery ch22.pdf
Ok here we go.
And this link
Thank you for the helpful links.
I see you have the XP9000. Is that really the XD9000? and how do you like it for your rig?
TR
To answer your other questions.
How long of a line? What ever your model winch can hold. You don't want to completely max it out though. Just keep it reasonable. The only time that you will think twice about if you have too much is when you have your wallet out. After that you will always find a need for more.
Keeping line on the drum. When some one tells you to keep one wrap on the drum they mean one time around the drum not to be confused with a complete first layer of wraps on the drum. THe first wrap is to put more friction between the drum and the line so you don't pull your stopper off.
Good Luck.
I've got the new slee bumper and put on a 9.5XP with a hawse fairlead. As I was putting it all together, I kept thinking that Christo must have designed his new bumper for this exact winch configuration.
I'm sure others fit too, but the 9.5XP went on nice and clean.
The nice thing about the shortbus bumper is that the winch cradle is cavernous. I do believe it's larger than the ARB cradle. My 12.5K fit in there easy as pie.
