winch size
Typical answer is that a minimum would be 1.5x the vehicle weight up to 2x the vehicle weight depending on what sort of use it will see. Easy trails, you could possibly drop to 1x the vehicle weight. But if you see a fair amount of rocks, snow, or mud then go towards the 2x end.
Also, with a snatch block you can double the capacity of the winch at the expense of line speed. Something to consider if the majority of your use is fairly easy but you want to be prepared for those 1% times that you need more.
8K will be plenty enough.
8k is, in my opinion, perfect for a mini truck. You will be happy with the M8000. I am going to plop one of the Smittybuilt XRC8000's on mine when I get my bumper finished up.
