Thanks bigdn.
My drive way is about 3' longer than my FJ40 so that method might not work so well for me.
Assuming I can find a suitable location let me see if I understand your method.
You spool out the line then use the rig to provide resistance while you stand by the winch and rewind the cable onto the spool? So you just walk along with the rig?
I don't think that would work with my 8274, it would be tough to stay out of the way and guide the cable.
Does that make any sense?
You read my sig line.Yeah, that's pretty much what I was sayin, just walk backwards in front of the vehicle, and make steering adjustments as needed. But, with the added knowledge of your winch being an 8274 (not just 'a doohicky in the front), I think I'd rather unspool the entire thing and hook it to a log or something and then winch that to the cruiser. If that's still too fast for you to control, double the line back to the cruiser and use a snatch block on the object you're using for resistance. That'd be easier, plus you'd have more control, since you don't have enough room on your own place to do it.
You can always come up to my place if you need more room.![]()
That's one advantage of a syn line; easy 1-person spool up.
Sorry Dan I know that's not what you wanted to hear.
