For something fun to do and have a piece of useable kit, I decided I would make my own winch extension with soft eyes.
List of parts used:
• 7/16” Amsteel Blue
• 3/4” nylon tubular webbing
• 1” Bluewater Milspec Tubular webbing
• #15 Tarred whipping twine
• Splicing Fid
• Lockstitch Needle
• Marking Pen
• Tape
• Scissors
Step 1:
Cut the material needed for the softeyes. For extra protection I decided to double layer the eyes. Bluewater Milspec Climbing webbing was used for the outer layer. This was cut to 12” sections. The inner layer is comprised of standard ¾” nylon tubular webbing cut in 11” sections. The difference in lengths will allow the inner layer to stay nicely tucked under the outer layer making for a nicer appearance.
Step 2:
Mark your bury with a total of three Fid lengths. (Fid=21 X diameter of rope). First mark is one fid length from Bury end. I mark it with a single line. Next go two fid lengths from Mark One and make Mark Two.
Step 3:
Create your eye length. I used a length of 12” for this. Start at Mark Two and measure out your eye and make Mark Three. Diameter: 12”/3.142 = 3.82”. I mark this as Mark Three.
Step 4:
By putting Mark Two and Three together you will see the size of your eye and be able to properly note where Mark Four needs to be. Mark Four is where your Bury will exit for removal of the Fid and to a secondary taper of the rope. Make sure Mark Four is beyond the end of your bury. This can also be done by measuring out four fid lengths from Mark Three.
Step 5:
Creating the initial Taper. Start Mark One. Mark touching pairs of strands. Skip a pair. Mark a pair. Skip a pair. Mark a pair. When you have done this, pull out the marked strands. Cut them off. After that I make sure to actually retuck the cut ends so that the taper is nice and clean looking. This will allow the splice to move smoothly and prevents the cut ends from getting frayed out during the process.
Step 6:
Attach the Fid.
Step 7:
Run the webbing onto the rope. Start with the ¾” webbing. Pull it down the between Mark Two and Mark Three. Make sure the webbing is not twisted. As you can see it is twisted in the pictures. Just a simple twist and it will be nice and straight. Next repeat the process with the 1” webbing and side it over the 3”4” piece When done make sure the 1” webbing is overlapping the ¾” by ½” on both side and centered between Mark Two and Mark Three.
Step 8:
Now it is time to start the bury. Take your fid and insert it at Mark Three. Make sure you have not twisted the rope and your webbing on the eye will be nice and straight when the eye is pulled tight. Keep milking the fid down and exit at or beyond Mark Four.
Step 9:
Secondary Taper. Take off the Fid that has just exited Mark Four. From the bury end cut three single strands in a row just a few inches from the end. This is very similar to the initial taper in Step 5, but don’t skip strands. This step can be left out but I like taking the extra step.
List of parts used:
• Splicing Fid
• Lockstitch Needle
• Marking Pen
• Tape
• Scissors
Step 1:
Step 2:
Step 3:
Step 4:
Step 5:
Step 6:
Attach the Fid.
Step 7:
Step 8:
Step 9:
