Will my tires rub?
I have 17x9 wheels with 5" back spacing so +0 offset.
Wondering if I will rub with Toyo MT 37x13.5x17 tires, does anyone have the same set up?
I'm currently using J springs with 1 1/4" spacers up front, no spacers in the rear, hoping someone with the same set up can chime in.
I am running 17 x 8.5 wheels with 4.5 BS. When I moved up from 315s, I ran Nitto Trail Grapplers 37 x 12.5. No spacers. I had nominal fender rubbing on the rears on the inner sidewalls and the top inboard corners. I also ha significant rubbing on the outside corners on the trailing end of both the fender and flair. I trimmed the edge of the flair and "massaged" the fender with a 2x4 and a 4# drill hammer. I could still make minimal contact when standing it on only one rear tire. I wore those tires out in 55000 miles and replaced them with Cooper STT. 37 x 12.5. Same sized tire but notably narrower at the shoulder. This has resulted in even less rubbing. The key to running 37s with minimal rubbing without removing flairs and cutting fenders is run narrow ties . Wider wheels and tires may limit suspension travel significantly. YRMV. John
