- Joined
- May 6, 2007
- Threads
- 352
- Messages
- 3,413
- Location
- San Juan Puerto Rico
- Website
- www.facebook.com
Will a caliper/rotor from a 1993 up fit on a 1992 and be able to use 15 inch wheel???
I have replaced rotors, hoses master cylinder, booster, drums, shoes and pads. Bled the system really good and still not 100% satisfied. I had worked with brakes for about 20 years. I find that the disc brakes on the 92 are a little small in relation to the size and weight of the vehicle. If I'm not mistaken are the same as the FJ40 and the 60.Have you checked and reconditioned the current braking components to make sure that everything is working 100%? Age has a tendency to decrease the performance of braking components.
Did you had 15 inch wheels??? Will be easier in my case. I removed the dust shields already! Thanks!Bigger brakes will fit. Just did it to my '91. It's tight. You need to cut down your dust shields and grind ~2mm of material off the calipers, but it works.
Can you remove the LSVP?Yeah. Factory 15" 1991 Land Cruiser rims. The bigger brakes are noticeably better, but could use a bit more help (they still feel a little spongy, even with a new master cylinder and what I felt was a good brake-bleeding). My next step is removing the LSPV for more firm, responsive 50/50 braking (hopefully).
Forgot to mention, I replaced those when I lifted the truck....Wow, you've been busy. The only thing left are the rubber lines but that shouldn't impact a whole bunch.
