As posted in another thread, I'm thinking about swapping out my Tacoma axle for an FZJ 80 axle and have two more questions:
1. My T-case output is centered and the FJ diff is not. This is my daily driver, so does anyone have experience with running an off-set diff on a daily driver with a centered T-case (or a centered diff with off-set T-case)? Will it work if I put a double carden U-joint on both ends of the drive shaft?
2. I have SOA leafsprings. They measure 37" apart from inside to inside. So, I will have to weld the spring perch on the passeneger side 18.5" from the center of the axle. Will there be enough room there with the diff and E-locker being off centered?
Thanks
Thanks
