Will an engine rubuild kit make the engine as new again?
Copenhagen, Denmark
Hi,
I noticed, that in Australia you can buy complete engine rebuild kits for 1000 to 1300 AUD. They contain new pistons, sleeves, rings, all gaskets, main bearings etc.
If you have an engine that has gone lets say 500000 km, will it be like a new engine and can do another 500000 km using such a kit?
Lucas
If done correctly, and all other tolerances are checked/fixed, such as crank, oil pump, timing gears... and coupled with a pump and head rebuild, the engine is like new.
Just dropping in new bearings, pistons and sleeves will not be enough.
cheers,
Jan
agree with Jan, the kit alone is not enough, it will cost a lot or a bit more to have that ALL new engine.
Crankshaft can be machined and bearings oversized.
I also noticed replacement pistons dont last as long as original. My replacement pistons from thailand or taiwan no longer has the oil grooves on the surface whereas the original toyota pistons still does after all the years.
A lot will depend on the machining and assembly also. All things being equal it should last as long as the original. How it is driven is probably the biggest factor.
Its also hard to come up with a definitive answer because very few owners keep a vehicle long enough to find out.
A friend had 2F rebuilt in the mid 80s,it wasnt the greatest job. The friends of friends who did it in a farm shed left out parts ,used some incorrect parts but it was still going strong 20 years later after many fishing trips and one trip around australia until the FJ45 it was in rusted away to nothing.
Not sure if this is the same as other peoples experience.. but my recently installed fully rebuilt 2H seemed to get progressively smoother and more powerful over the course of the first 2000-3000klms after install..
So dont panic if its intially just a touch disappointing..
