wierd clutch issues...
Bozeman, MT
Howdy-
Two weeks ago my clutch started to act like I had some fluid leaking or air in the line. I was having to double pump to make it into gear. Actually like a 1/4 pump then a full one.
So I bled the clutch fluid and all my symtoms went away. However, I was not missing any fluid... at all.
Today, my cruiser is doing the same thing, and it is not missing any fluid. Could it be time for a new master cylinder, I rebuilt it around 6 years ago? Could fluid be squeezing past the pistons to allow me to drop in pressure at the slave cylinder?
For what it is worth the slave is only a few months old.
thanks in advance-
Rezarf <><
could be passing around the piston? or could be the flexible line is expanding?
I dont think the hose would be expanding, because it hasn't happened for over a week now. Can the piston thing happen?
Why do you think bleeding would give temporary relief?
thanks-
Rezarf <><
Just bought a cruiser 3 mo. ago and had exact same issue. No fluid leak, but had to pump the clutch to get a shift. Get under the truck and have someone push down the clutch and hold it, watch the slave cylinder push the shift fork and see if it holds, it'll probably start to creep back towards the cylinder. I replaced my clutch master cylinder and have had no problem since. The o-rings in the old cylinder were toast. I also bought a slave cylinder just in case, their so cheap. Most people say the slave seems to go shortly after you replace a master cylinder so if you want to do it right, do them both. Hope this helps....
Take note of rookie mistake
Was so proud of myself being able to maybe help someone with my limited cruiser knowledge that I replied to this post. After I replied I noticed the post was from 05'!:doh: REZARF, I hope you figured your problem out by now, but if not your patience has paid off!
