Why you base line a rig.
Arkansas
Earlier this year I picked up "Beaulah" and have since changed a lot of hoses, fluids, filters, thermostats, radiator caps, etc. Most if not all of this was stock 20 year old equipment. The PO had effected the PHH bypass so that wasn't high on the list.
Today while changing the heater hoses and heater valve out with OEM parts the realization that Toyota's original equipment although 20 years old is likely less suspect than some of the repairs effective over these 80's lives.
When I pulled the bypass installed by the PO to my surprise I found the barb end of the heater valve missing! No leak was present prior to the valve swap, however, it had to be a good source for a failure on the road.
I do have a question for those who have replaced the heater hoses on the driver's side below the heater valve. Have most people replaced the section connecting the steel tube to the firewall with a straight piece of Green Stripe or other heater hose or is there a part number for a Gates hose that will work?
I marked the hose I am asking about with a yellow arrow in the pic
Shhhhhhhhh! Be quiet. My radiator tank looks like that too.
You have a good point if i understand you right. As i have said before. The old 20 year old eom parts need to be replace as regular pm. When i buy a truck i know that. But i am much more woried about "repairs" that the PO had dome by some crap shop using crap parts.
People get really excited about service rrcods when buying a truck. Sure if they are done by a reputable LC shop using oem parts. Buy if someone has recipts from Billy Bobs automotive doing a HG i would much rather have the 20 yearold OEM HG.
Whatever, the subject of the thread is the heater valve, mine, along with most of the rigs I wheel with have "crap" valves, (guessing that is what you are calling aftermarket parts). Its a simple part, easy to bypass, so :meh:.
Mine and several others have aftermarket radiator and head gasket. If you would like the blown original OEM HG, I think its still hanging on the hook?
Yes and no. I probably didnt explain my self well. I would rather have oem than after market and i stanf by that. But sure, new aftermarket parts are proably better that crapped out 20 yearold oem stuff. No argument about that. But whay not put good oem parts in?
But my real issue is comming down to crappy work done by crappy shops. I have seen so much half ass jobs where people screw up simple jobs that make bigger problems down the road. So that is a big part of what i am saying.
When you have oem old wheel bearings that need replacment you know what to expecs you get in there. But if some shop worked on it 5 years ago you run the risk of things being pressed in wrong or things being gouged out by someone using a chisel. To remove seals and on and on. I juat dont trust other peoples work for the most part.
If you want to replace dried out oem coolant lines with good green stripe hose sure that is a move in the right direction over old dried stuff. No real argument there. Sorry if i was not clear about what i was saying.
... But whay not put good oem parts in? ....
So, anything that comes out of a Toyota package is automatically the best, all others are crap parts?
... But my real issue is comming down to crappy work done by crappy shops. ...
Have repaired plenty of botched dealer work.
If it worked 25 years on my Pigi than the answer is good enough for me
With after market you do not know
I put after market radiator, it cost me double then OEM just because I knew it better
Well...kind of. The OEM stuff lasted 20 years. It is of known quality. So there is that. Is it the "best" 100% of the time. No. I would argue that King shocks are better that oem. If you Want slotted drilled roters i am sure you can find stuff that is better than oem. There are other exceptions as well. But when people go down to autozone and buy the cheapest part they can i dont think it stacks up to oem quality.
[/QUOTE]
Have repaired plenty of botched dealer work.[/QUOTE]
I never said a dealership was a good shop. But i would say shops like ACC, Robbie, Slee and several others are. Do they make mistakes? Sure but i would bet they consistently do quality work the same as you do. I have also seen quality shops make mistakes, but they will take the time to make it right.
If you feel aftermarket parts are better than oem thats cool. But in general i am more comfortable with parts that say Toyota on the box unless i have a specific reason to choose something else.
I am really not trying to be dick or argue with you. I have read a bunch of your posts over the years and admit that you have more experiance with this than i do. But this is just how i feel about what i want on my truck.
Well...kind of. The OEM stuff lasted 20 years. It is of known quality. So there is that. ...
In some cases, agree, we just got some dealer battery terminals, prefer them. Some parts prefer aftermarket, belts would be one example, have seen much better life from them. Some parts can be had from the OE, an example would be bearings, if you know the number, the same Koyo bearing can be had for a fraction of the price. Lots of the OE suppliers have strong aftermarket support, like Denso, Aisin, etc, often the same parts, unless you care about the color of the package.
Its nice that you want to support Toyota, but they don't care about your old Cruiser, in fact, likely would prefer that you get rid of that dinosaur and get a new Prius. We often work on 40+ yr old Cruisers, having solid aftermarket support from companies like Cruiseroutfittiers and even Rockauto is key to keeping them on the trail, without them it wouldn't be possible, too much stuff is discontinued from Toyota.
I wasn't trying to start an problem. Just point out that when base lining it might be a good idea to look at known previous repairs to see what quality of work was effected. In my case the heater valve end was broke doing a PHH bypass. Did it hold - Yes. Was it as designed and as good as factory - No (the barb end was broke off).
The heater valve I bought is from local dealer. they give me good pricing. It is a Denso valve and says so on the valve. I am sure a Denso part could be acquired from a parts house and would obviously be as good as Toyota in this case.
