Why are these lights on?
Carlsbad, CA 92008
Man, I was driving my Cruiser yesterday, and several lights came on and they keep appearing when I drive.
A/T OIL TEMP
BRAKE
(Picture of Oil can with liguid wave underneath)
and the Big Red light above the voltage meter.
they all come on at the same time.
I have a brand new trany flush and a new oil change as of yesterday and also had my car detailed.
I'm wondering if something could have been knocked loose with the vacuum or something?
Dave
That's the standard low voltage warning.
Something's up with your charging system, maybe or maybe not related to the recent work. Start simple: check the battery connections, etc.
Curtis
How does the brake light refer to the charging system? I thought that was purely for either a parking brake sensor or low brake fluid in the resevoir - am I thinking of a different brake light, or just wrong?
That's just how it alerts you to low voltage. Not sure why.
Mine started to do that when my old alternator went south.
Wierd - but good to know.
I didn't even have a chance to grab my FSM from the truck before IKA1988 responded!
That's usually an alternator/low votlage problem. I bet that the lights went on faintly, not like you just turned on the switch. If you have problems at night when your headlights are turned ON, all the more reason to suspect the alternator. If the truck stops a little after this happens is another indicator.
Have these lights ever been indicative of a loose battery cable or dying battery?
I've got the same lights. Seem to flash when I hit the blinker, or I hold up 2 or more window switches when the windows are already up.
I had my alternator rebuilt a couple months ago too. I'm leary of it going out so soon.
Any power draw will cause the lights to go on when there is a low voltage, from what I experienced in other vehicles (not particularly LC). Check the simple stuff first before thinking it is an alternator.
IIRC, a brush set is pretty cheap, and is not difficult to install..... That may not be the problem with the alternator though--could be voltage regulator etc....
X2
I have a set in my garage and will probably swap it out as a 120K PM.
Ditto;
My vote is also against a local rebuild; just not worth the hassle; they use much cheaper components than a Toyota OME product. I ran through two local rebuilds in two years and finally saw the light.
Definitely check your battery connections etc; if you had some sort of "Premium service" done by yahoos; who knows what they attempted to clean, move, grease, bump, pull, yank, etc,etc,etc,etc.
You can take it to an Autozone, etc and ask them to check the system for you.
No charge.
Good luck.
g
