Who’s running K03s?
kcjaz
Olathe, KS
I’ve got 17K miles on my K03s on my Tacoma (265/70R18). I was planning on just going to K03s from the K02’s that are on my LC (285/17R17). A buddy of mine just recently got a set of K03 35s but the tire shop really struggled to balance them and used a lot of weight. They told him just to get a different set (brand) of tires and they would exchange with full refund. I’ve seen a couple things on the Internet that are negative regarding the KO3s and balancing, at least in larger sizes. Wondering if anybody’s experienced this here.
I really like the K03s on my Tacoma and have no issues.
I had issues with balancing 275-70r18 E load KO3, switched to Toyo AT3 for that vehicle. No issues with balancing 265-70r17 C load or 37x12.5r17 C load KO3 (on my LX). In my experience the higher load range tires are harder to balance. Besides the balance issue, I like them on and off-road.
My Tacoma K03s are E load. Probably could have backed off for that rig. It’s daily street service for now.
Mine have been super good.
Heavy as hell (285/65R18E). Mine balanced very well, especially compared with the KO2. None of my KO3s have more than 1.75oz total weight each, so that’s a win.
Edit: checking my maintenance log, I was wrong—I had one tire that took 2.25 oz.
There’s a local Toyota influencer who got K03’s installed on her 4g taco. She didn’t think this was a problem until the YouTube comments started coming in.
I have them in 285/70/17 Load C on my 200, about 10k on them now. Just did 4k miles round trip to Colorado and back with a week of wheeling in the middle for Crockies, and they were excellent in all conditions.
That said took a crazy amount of weight and they've already been rebalanced once. Thankfully it's covered under my Discount warranty, but it's annoying. They're also noisier than the Toyo AT3's I had before.
Have 34s KO3s 285/75/17 on my rig, came from 33s 285/65/18. The KO3s were easier to balance, with only 1 tire that needed a little extra, at 2oz.
Feel like this is a known issue that the BFG K02 + K03 both struggle to balance. Nitto G3 and Toyo AT3 are alternatives that are both much better on this front.
I'm around 10K miles in on the K03. I love them for the reduced road noise compared the the Nitto Ridge Grappler's on the car when I purchase it. I've been back to DiscountTire 3 times for balancing as I have a slight vibration/hop above 50 miles per hour. They force balanced and rearranged two of the tires on the wheels last time and it's much better. The force balance numbers are low but I can still feel it. The tech said the E-load rating seems problematic although I can't get the K03 with any other rating.
I had a similar vibration with my K02s and and Discount replaced one of them because that said a steel belt was either broken or defective.
Any chance someone is running the new 35x11.5R17 size? I’m due for tires and I’m resisting the desire to step up from the tried and true 285/75R17. It’s available in a C versus an E. I’m not really looking to do any additional work to make it work on a non-BMC, non-relocated KDSS truck on Rock Warriors. So I suspect that’s wishful thinking since the current tires are already a tight fit. Gaining .64” in OD and .25” in width sounds insignificant but I suspect that’s deceiving.
My 285/75T17s just barely fit with some rocker panel trimming. I brush the KDSS arm. Any bigger will require something be done to KDSS. I need new tires now and would love to move up to a 35 but I just don’t want to figure out fitment right now.
I currently kiss the KDSS bar on one side at full lock. I still have rear mud flaps that are molded all the way back to the body mount. Like you, I’m not sure the juice is worth the squeeze for my use case. I might order a set simply to see how they fit. I think a buddy also has a set of spacers that I can throw on to see how offset changes impacts the fitment. But odds are I’ll press the easy button and not bother.
When did you get them? How did they do in the wet snow up the passes? I need to replace the KO2s on my 200 and hope the KO3s do a better job.
January, been through a full season of mtn passes, rain, summer and zero complaints. Wet traction is fine, snow traction was good too.
Got my 285/75/R17 K03s mounted today. Balance weights are:
RR 5.5 oz
LR 5.0 oz
LF 2.5 oz
RF 1.5 oz
These don’t seem crazy to me but then again, I don’t really have any frame of reference as I’ve never paid attention to this. From the old glue marks, I’ve had more weight in the past.
One oddity is that they used an inside edge weight on the 1.5 oz wheel. My only concern with that is the potential of a rock removing that weight.
