Whining noise in Reverse?
New to Seattle, WA
I have pretty steep drive way and was backing up it today and the it stopped and whined until I let off the gas, tried again.. didn't back up the hill just whined???
This must be bad right?
Check ATF level?
Have you backed up your drive previously like this, with no problems?
Have you changed fluid recently? What fluid are you running? Dex II/III?
(Sorry, that's all I could think of...)
there is a thread somewhere in the forum that the trans in the later cruisers were missing a few check balls and that under load in reverse the cruisers would not go anywhere, I have experienced this while backing a heavy trailor in reverse..
Thats strange...backing a trailer I have never had this happen...soo this would suck if you had to back up a hill in the woods...
Yes it does suck, I had to put it in low range to move it, I thought I broke something but I didn't, it just kind of revs up then clicks a little when under load, with the load off it worked fine again. There is a guy in AU making throttle plates for these transmissions to give a firmer shift and fix this problem..
My power steering pump sometimes squeaks while in reverse.
